Just How Loud Is The BT3000?
  • Just How Loud Is The BT3000?
    Just How Loud Is That BT3000?
    By Jim Frye
    A lot of times you see people extolling the sound virtues of the induction motor and in the same breath stating that the universal motor is too loud. You almost always see this in relation to the BT3000 (BT3K), which has a universal motor. It’s funny that you don’t hear people complain that their router or circular saw is too loud, but then no one makes a router or circular saw with an induction motor. You probably couldn’t lift one if they did. Only once have I seen, in print, any comparison of the BT3K’s noise level with other table saws. A couple of years ago, Fine Woodworking Magazine (FWW), did a comparison test of the contractor type saws on the market, including the BT3K. The noise levels for the contractor saws ranged from a low of 80 decibels to a high of 90 decibels. The BT3K tested at 93 decibels. By comparison, my QSP industrial ShopVac measures 93 decibels when it is connected to the BT3K. The nosiest contractor saw was the Grizzly G1022 at 90 decibels. So, a stock BT3K is 3 decibels noisier than the saw that is usually touted as being a better buy than the BT3K. By the way, it is a bit difficult to discern a 3 decibel difference with the human ear.
    The U. S. Department of Labor has published regulations concerning noise in the workplace and a review of the numbers should help the reader understand noise measurements. Because the human ear can hear a vast range of sound levels, the Decibel Scale was created to make it easier to classify sound levels. The scale is logirithimetric so 90 dB is 10 times louder than 80 dB. The decibel scale starts at 0 which is considered to be the Threshold of Hearing and 130 is considered to be the Threshold of Pain. The Other levels of relevance here are:
    65 Normal conversation
    75 Average factory
    80 Loud music
    90 Beginning of unsafe levels
    110 Amplified rock music
    120 Jet airplane taking off
    150 Immediate hearing loss
    The recommended exposure times to various noise levels has also been published.
    Decibel Level Maximum Time per Day
    90 8 hours
    92 6 hours
    95 4 hours
    97 3 hours
    100 2 hours
    102 1 1/2 hours
    105 1 hour
    110 30 minutes
    115 Less than 30 minutes
    I measured most of the power tools in my shop that see frequent use. I was somewhat surprised at the noise levels they generated. These measurements were taken with the meter in approximate position of the operator’s ear when operating the particular machine.
    Delta 6” bench top jointer, 6,000 rpm 86 dB
    Delta 6” bench top jointer, 11,000 rpm 96 dB
    Dremel 10” bench top band saw, 970 sfpm 68 dB
    Dremel 10” bench top band saw, 2,900 sfpm 86 dB
    Delta 12” bench top drill press, 620 rpm 71 dB
    Delta 12” bench top drill press, 3,100 rpm 74 dB
    Shop Vac QSP industrial vac 93 dB
    Bosch 2 hp router, 8,000 rpm 70 dB
    Bosch 2 hp router, 25,000 rpm 102 dB
    Ryobi 3 hp plunge router, 10,000 rpm 92 dB
    Ryobi 3 hp plunge router, 28,000 rpm 103 dB
    Makita 1/2” corded drill 102 dB
    Bosch random orbit sander, setting 1 87 dB
    Bosch random orbit sander, setting 6 98 dB
    Black & Decker jig saw 97 dB
    DeWalt biscuit joiner 106 dB
    Black & Decker 1/4 sheet sander 102 dB
    Black & Decker 7 1/4” circular saw 109 dB
    It is apparent that how the motor is installed in the tool has as much to do with the noise levels the tool generates as the type of motor does. The Dremel band saw with it’s induction motor is just as loud as the Delta jointer with it’s universal motor.
    As an additional comparison, I measured a PowerMatic model 66 table saw. These saws are considered to be the best 10” table saw in the business and I thought it would be interesting to compare it with my BT3000. I have a relative who has a PM66 and his workshop is nearly identical to mine. Both shops are in the basement with open joists above. Both shops have two concrete walls and two wood stud walls. Both shops are 12’ x 12’ in size. Both saws sit on rubber wheeled stands. I measured both table saws running in the middle of the shop floor with the meter at my ear level standing in front of the saw. The PM66 measured 86 dB and the BT3K measured 87 dB!
    The obvious point here is that it is extremely important that you use proper hearing protection when working with power tools in your shop. I have a set of ear muffs that are rated at 29 dB reduction. These muffs will make even my worst noisemaker quiet enough to fall below the federal exposure guidelines.
    I have been working on several noise and dust collection projects for the BT3K over the years and they have reduced the noise level of my BT3K to put it in the same noise range as the contractor saws. The modifications I made to my saw were rather simple and inexpensive. They are as follows:
    1. The interior of the saw cabinet was covered with 1/4” thick by 2” diameter disks of clear silicone sealer to quell noise from vibration. Cost $5.00. Other BT3K users have lined the saw cabinet with sound deadening foam to reduce interior noise of the BT3K.
    2. The bottom of the saw cabinet was closed off with a dust collection pan to keep stray sawdust out of the area inside of the stand. Cost $4.00 for the hot melt glue sticks used to glue the corrugated cardboard parts of the pan together and a can of silver spray paint.
    3. The triangular openings at the top front and rear of the cabinet were closed off with duct tape, but scrap wood would work just as well. Cost $0.00.
    4. The vent slots at the left side of the cabinet were closed off with duct tape also. Cost $0.00.
    5. The rear dust port opening in the cabinet was closed off with an articulated cover. Cost $2.00 for a piece of 1/4” plywood.
    6. The stand was modified to sit on three rubber tired casters. I used two Ryobi BT3K casters at one end and a swiveling, locking castor at the other end. Cost $25.00.
    This leaves only the motor vent slots on the right side of the cabinet open, along with the tilt/elevation hand wheel slot on the front and the blade slot in the throat plate for noise to escape from the cabinet. Total cost for noise reduction on my BT3K was $36.00. I am in the process of enclosing the metal saw stand with a cabinet made from 3/4” plywood. The mass and sound deadening characteristics of this enclosed cabinet should reduce the noise level of my saw even further.
    Original PDF Document:
    bt3knoise.pdf
      Posting comments is disabled.
    Latest Articles
    • Screw friction products EZ-Grip and Screw Grab?
      by LCHIEN
      I was reading an article about fasteners the other day.
      They mentioned a couple of products I had not heard of before:
      EZ-grip and Screw Grab
      Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
      You can find them both at Amazon.
      Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...
      04-07-2022, 10:58 AM
    • A Cure for the Shim Problem on the Ryobi BT3000
      by twistsol
      Originally written by Norm Havens and re-posted here.
      Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
      December 3, 2000 I must be totally star-crossed this week . . .
      "Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...
      08-29-2018, 11:21 AM
    • Ryobi BT3000 and BT3100 Manuals
      by twistsol
      The manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
      11-21-2017, 09:23 AM
    • Lonnie's No Measure Alignment procedure
      by Lonnie in Orlando
      Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
      04-29-2015, 09:49 AM
    • BT3K Shim Replacement
      by Black wallnut
      Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
      Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
      Step 2: remove left side cover and dust shroud.
      Step 3: remove the four...
      04-29-2015, 09:41 AM
    • BT3000 To 3100 Shim Upgrade
      by crokett
      Upgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
      Before you begin:
      Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
      verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
      ‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw.
      These instructions assume a stock
      04-29-2015, 09:33 AM
    The SawdustZone Statistics
    Topics: 61,770   Posts: 561,925   Members: 20,860   Active Members: 26
    Welcome to our newest member, handcraftedmodelshipsca.
    What's Going On
    There are currently 7080 users online. 1 members and 7079 guests.
