Simple DIY Shop Made items for use in the shop - what have you made?
    • 21980
    I look forward to seeing your pic/video as I have been searching for a good DC option of my DP.
    Posted! Go to the post #18 in this thread.
    • Relative
      • Mar 2007
      • 109
      • Garden Grove, CA
      • Ridgid R4512
      #32
      Handy chisel racks. Hang out of the way and portable to where I need them.
      Veterans are people who, at one point in their life, wrote a blank check payable to the United States of America, for an amount up to and including their life.
      • Relative
        • Mar 2007
        • 109
        • Garden Grove, CA
        • Ridgid R4512
        #33
        Mini bench. Raise up small items to work on or move it anywhere for a handy workbench.
        • Relative
          • Mar 2007
          • 109
          • Garden Grove, CA
          • Ridgid R4512
          #34
          The plug. Quick and easy way to size the vac to the port.
            LCHIEN commented
            I made one same idea to connect 1/14" hose to odd port on belt sander. Why do they make so many odd port sizes? The tricky part is tapering the plug just a little so it fits.
        • Relative
          • Mar 2007
          • 109
          • Garden Grove, CA
          • Ridgid R4512
          #35
          Router table stop blocks, bit safety shield, hold-downs. All adjustable in every way I could think of.
          • Relative
            • Mar 2007
            • 109
            • Garden Grove, CA
            • Ridgid R4512
            #36
            Pocket hole jig. This idea came from a magazine article - make some modifications. The pocket hole tool is from HF. Makes for a very nice platform to use the tool and store items for it.
              LCHIEN commented
              I like the way it folds up for storage
          • Relative
            • Mar 2007
            • 109
            • Garden Grove, CA
            • Ridgid R4512
            #37
            Couple miscellaneous items. Spline jig. Jig to set width for cutting narrow strips. Found the roller bearing tip works better than the UHMW tip. Shooting board. Clamp blocks for squaring up.
              • 9503
              Just knocked a new one together. A quick and simple glue bottle holder for Gorilla Glue. Not a table top rig though. I wanted it mounted out of the way...
                • 21980
                Here's a drill press jig I use to drill vertical pieces.- square, round, or even edges of small boards.
                Even though its a few inches high you can use it to squarely drill pieces much taller.
                Carefully attach pieces at right angles measured with engineer's squares and clamped while assembling. Click image for larger version  Name:	20170117_172116sm.jpg Views:	2 Size:	98.3 KB ID:	829088
                I undercut or bevel the bottom edges of fences so dust buildup and edge fuzz doesn't throw your pieces off and keep piece faces from contacting the fence intimately.
                Click image for larger version  Name:	20170117_172128sm.jpg Views:	2 Size:	91.3 KB ID:	829089
                Clamp the workpiece to the vertical fences to ensure that the drill is parallel to the sides of the workpiece be it a cylinder or a rectangle.
                THis does not rely on the ends being cut squarely as long as you have made your drill press table perfectly perpendicular to the drill bit!
                Works well for cutting multiple pieces - clamp the jig in place to your drill press table and drill multiple pieces effortlessly.
                You can make a taller jig as necessary, this one is probably good for stiff pieces up to a foot or 18 inches I would guess.
                Usually good for drilling holes from both ends to meet in the middle if you use the same two faces for registration. Click image for larger version  Name:	20170117_172027sm.jpg Views:	1 Size:	113.9 KB ID:	829087
                  • 9503
                  Storage shelf for sandpaper disks which I use for sanding bowls. Has a clear hinged door to keep out shavings, and a HF magnetic strip on the back, so I can orient it vertically, or horizontally.
                  [ATTACH=CONFIG]n826917[/ATTACH] [ATTACH=CONFIG]n826918[/ATTACH]
                  Love this!
                    • 21980
                    Here's another item I find useful that's very simple to build and use.
                    How many of you need to do some very narrow rips? I'm talking about making strips that are 3/8" or so square. Pretty scary when you contemplate doing it. Click image for larger version  Name:	push block 1.jpg Views:	2 Size:	183.7 KB ID:	829156
                    This is a sacrificial push block, shown bottom side up above. Its just a scrap piece of about 12" long 2x4. I crosscut the last 1/2" and screwed it back on the end shifted about 3/16 to 1/4" off. This gives the hook to catch the end of the workpiece.
                    As you can see I've used it for many narrow rips - you set the blade so it cuts into the bottom of the sacrificial push block and the height is just above the workpiece thickness. Place the workpiece right up the fence. Use a ZCTP for sure! Because you want your workpiece to be fully supported!
                    Place the push block on top of the workpiece with the hook at the tail end of the workpiece.
                    For narrow pieces I use an even thinner piece of scrap to push the workpiece to the fence as I place the block on the workpiece to make sure the width is cut right; to do that the workpiece and the push block have to be flush to the fence. Click image for larger version  Name:	20170131_141520sm.jpg Views:	1 Size:	93.6 KB ID:	829157
                    I really use the thumb on one side of the block and four fingers on the other side. Make sure as you push the block stays flush to the fence.
                    Your fingers will be safe as they are on either side of the blade, and the blade will be buried in the block, The blade will exit out the rear of the block so keep your hands away from the rear of the block.
                    Note that if you used screws to attach the hook piece, place the screws up high! The push block is tall enough to keep your hands clear!
                    The thin scrap of wood in the foreground I used to push the strip all the way against the fence as I place the push block on top, Then I remove the thin scrap so it doesn't drag along. Not enough hands here - using one to hold the camera..
                    In the picture above I am cutting down a 3/8" x less than 1/2" wide workpiece to a 3/8" x 3/8" square, you can just see the tip of the piece in front of the push block; the hook is pushing the other end.
                    When it gets too chewed up, make another one!
                    • tfischer
                      tfischer commented
                      Pics aren't working for me either. I'm curious to see them though... when I need narrow rips I use my Grrrippers
                      LCHIEN commented
                      Should work now. I'm afraid I linked the pics to an location on my computer first time so they showed up for me. Now they are in the SDZ server, I hope.
                      atgcpaul commented
                      Loring, I actually have the same "jig"--a 2x4 offcut I use as a pushstick when I need to make thin rips. I normally use an aluminum pushstick but I don't want to get that close to the blade with metal--even though it's not a Sawstop.
                      I also have a Gripper but I don't have enough practice with it to use it comfortably for thin rips.
                    • 21980
                    Updated the pics in the preceeding post. since you guys couldn't see them. Should be 2 pics visible.
                    • tfischer
                      • 2349
                      That's a neat jig, much cheaper than a Grrrippper. But I loved my Grrripper so much that I got a second one so I can do longer rips with the hand-over-hand technique
                        • 21980
                        Continued in Part II
                        https://www.sawdustzone.org/forum/di...u-made-part-ii
                        • Wedic1
                          • May 2021
                          • 5
                          • USA
                          • Bosch table saw GTS1031
                          #45
                          I'm planning to do the little Home DIY, It's a little phone case stand, but I haven't design yet and I finding light and perfect wood for it!
                          I think phone case should be similar like smallest chair!
                          give me some suggestion to do better!
