Late To The Party
  • mangorockfish
    • Mar 2017
    • 19
    Late To The Party
    Kind of new here. Registered quite sometime ago but haven't been here in a long time. I just bought a BT3100 last week from an older gentleman that told me he had cut one piece of plywood and never used it again. Used his bandsaws. Said that it sat idle all of its life except for the one cut. The saw looks like it was brand new. The stand has a few small scuffs but I think I can clean them up. Now for the real kicker. I'm going tomorrow to pick up another one from an online auction that looks nicer than the first one in the pictures. I have wanted a BT3100 ever since I found out about them and now have two. Can't wait to start using them. I do mainly planter boxes and picture frames for the wife. What dado blade works best on these saws? Thanks and glad to be here.
  • Black walnut
    • Aug 2015
    • 5515
    Congrats on your find! Any good quality 6" stacked dado will be good to use with this saw. *' and you will have clearance issues if you want to run a full stack. I have a freud stack and added a 3/32" chipper. Make sure that you make or buy a dado throat plate. You should also use both factory blade washers, and take out one or both of the spacer washers.
      There's a lengthy discussion of dado blades for the bt3x saws in the FAQ linked in my signature line below.
      it explains why but the recommendation is a six inch stack dado is your best operational dado. And really good for any reasonable cut depth. Freud SD x06 are good. I think they make a 206 and 306 models.
      By the way, welcome!
      • Black walnut
        • Aug 2015
        • 5515
        Freud actually makes three 6" stack dados; 206, 306, and 506. The difference is cost to consumer, number of and sizing of chippers, and number of teeth on outside blades plus the number of spacer shims. Most members have chosen the 206 set, or a different brand, due to availability and cost.
          I have either the sd206 or SD 306, I'll have to check. But I've been very happy with it.
          I have the sd308 but it's too big to fit properly without compromise over 1/2 inch width. I almost never can think when I need a 2.5" deep dado. 1.5" with a 6" stack is good foe everything.
          • Stile_ss
            • Apr 2024
            • 6
            It's never too late if you compare to your self, better late then never my pal
              Welcome! Always good to have new friends joining in.
              • nikiznb
                Handtools only
                • Jul 2024
                • 4
                Congrats on your find too!!!
                  It has to be a 6" stack dado set. I have the Oshlun SDS-0630 https://amzn.to/3WkQMll
                  The Freud 6" Pro stack Dado set is pretty well regarded. https://amzn.to/3LpvE7g
                  Do not use an 8" with these saws, do not use a dial / wobble dado with these saws.
                  • pearson
                    • Mar 2025
                    • 30
                    Hi there! Another newbie here. I really would like to start some basic woodworking projects, especially after reading macorner reviews and understanding you don’t need extra skills for that. I’ve always been a little intimidated by the idea of woodworking, but after checking out some of the beginner-friendly tools and tutorials, I feel more confident. Plus, it seems like a great way to spend time creatively and end up with something useful at the end.
                      Hello, welcome.
                      • pearson
                        • Mar 2025
                        • 30
                        Thanks a lot!
