Sanding belts keep blowing up!
    So yeah, it's been a while since I have replaced the sanding belts on both my Rigid oscillating belt / spindle sander, AND my Chicago Electric 4x24 belt sanders.
    I had some Harbor Freight 4x24 80 grit belts in my spares, threw them on, and almost instantly they came separate at the glue joint. I no longer see these on the HF website BTW.
    FWIW, sanding curves into a panel and having the belt come undone on you stings a bit...
    I am taking a shot at a 10 pack of Powertec 40 grit belts.
    Will keep you posted on how well these do.
    FWIW, I have used Powertec sanding media over the years with good results.
    WIsh me luck!
    Oh and FWIW, I kind of need these soon / now. I am making some custom items for camping (support stand for on demand hot water heater / shower).
    • 3791
    I can’t remember the title of a previous post when all of my belts turned into long skinny sheets. My research showed that the tape strip used to splice sanding belts is time sensitive and has a limited shelf life. You never know how long a belt has set in someone’s warehouse.
    I am using HF 6x48 belts with really good results. A 5 pack for $15 vrs 1 belt from Lowe’s for $35.
      • 3791
      I have bought sanding belts from Online Industrial Supply with good results and fast shipping.
        • 22106
        probably too old. Glue only good for a year they claim.
        Could not find a tape that would hold despite trying for two whole days to reassemble them.
        PVA wood glue bonds really well to the belts but finding a thin filament fabric that would stand up was not possible - I tried pieces of Tyvek envelopes/
        Keep your space belts in air conditioned house, not garage.
        Check out this thread
        https://www.sawdustzone.org/forum/di...-power-sanders
        and
        https://www.sawdustzone.org/forum/di...plice-breaking
          Oh yeah. I go through maybe 2 belts a year. So theese were well over a year old...
          Why the heck do they make them with more or less a timer built into the glue? They really sting when they let go!
          • Jim Frye
            • 1364
            • Maumee, OH, USA.
            • Ryobi BT3000 & BT3100
            I agree that the tape join on sanding belts have a shelf life. I bought a bunch of 3x21 belts at the local tool store because they were on sale. After a few years, they all separated at the splice when first used. My basement shop has a consistent 62-66 degree temperature and the humidity is regulated by a dehumidifier, so the environment is not a factor. Now I only buy them when needed.
            Jim Frye
            The Nut in the Cellar.
