Hanging/Storing nailers
    • 3195
    I am just wrapping up a shop re-org and have been working on making better use of storage and ease of access to tools. I just installed a new air hose reel and have it running to my compressor that is in my outside attached enclosure along with my DC. I had been just keeping my nail guns in a bag in a cupboard but that wasnt great. I would like to hang them on the wall by the hose reel and wondered how others may have done this or maybe there is a better idea out there.
    If any of you do have something like this would appreciate a picture or 2 and a description if construction isnt obvious. Thanks!
    • 2900
    Pegboard may be ugly, but it's simple and it works ... These are my construction nailers. The finish nailers are hung the same way in the other shop but I didn't feel like walking down there for a photo.
    Construction Nailers
Name:	Nailer Hanging.jpg
      I haven't built it yet but I plan a cabinet I think I saw on New Yankee Workshop and had in my last shop. It is a foot deep with 3/4 shelves, fixed, with 1/4 dados about 2 inches apart. Dividers go into the dados (luan plywood) to create spaces for tools you want readily available. One of the tools that go in this ate my nailers and staplers. And my cordless tools.
        • 3195
        Well I went with the easy and quick approach. had some pieces of peg board lying around so thats it for a while at least.
          • 3568
          [ATTACH=CONFIG]n825645[/ATTACH] [ATTACH=CONFIG]n825646[/ATTACH]
          Last edited by capncarl; 06-03-2016, 09:37 PM. Reason: It is screwed up and needs fixin
            • 3568
            Just for laughs I'll try to attach the photo again. The long nail gun in the lower corner is an old Stephens 12 ga single barrel break action with plastic stocks. It shoots well and kicks like a mule. I like to keep it handy just in case something nasty comes up.
              Internet Fact Checker
              • 20966
              Mine, mostly in the original blow mold case or cardboard box or a wood case made for it.
              Lined up on a shelf on edge next to each other, a P-touch label on the visible side so I can identify it quickly.
              offhand,
              18 ga x 2" Craftsman
              18 ga 2" HF
              18 ga 1.25" Bostich
              16 ga.x 2.5" Craftsman
              16 Ga. Bostich
              1/2" crown stapler - Craftsman
              1/2" crown stapler, HF
              1/4" crown stapler - HF
              23 ga x 1"pin nailer
              Yes, there seems to be some duplications - I have too many nailers.
                • 9215
                I don't have a photo handy but... I hang mine on the pegboard of my shop cabinet doors, head up so as to minimize the leverage put against the peg board and hopefully keep it from ripping out. I have one that doesn't hang from the pegboard, simply because it is too large, the framing nailer. It hangs on a long nail driven into the stud below the cabinet and behind the lathe.
                My nailers are..
                #1. HF 21 degree Framing nailer.
                #2. HF 3 in 1 nailer / stapler.
                #3. HF 23 gauge pin nailer.
                #4. HF 16 gauge finish nailer A.K.A. the leaker. It had an air leak when I bought it, but I waited too long to get a replacement, so I fixed it with a thin film of black RTV. It won't want to come apart easily if it needs fixed down the road, but replacing it should be dirt cheap...
                FWIW, my framing nailer has spent more time out of my shop on loan seeing HEAVY use than it has in my shop or in my use. I have no intention of buying a roofing nailer as the guy that uses the snot out of my framing nailer has a roofing gun I can borrow when I need it...
                I do want a HF 18 ga brad nailer, and have the space for it...
                  • 9215
                  [ATTACH=CONFIG]n825634[/ATTACH]
                  That's the method I tried at first. You are going to want to use at least 2 hooks per nailer. At least I did. My pegboard ripped out when I only had one peg per nailer...
                    • 2900
                    I've probably just been lucky, but they've been hanging that way for about a decade with no issues. As part of the remodel, we need to take down the ceiling in the garage and I plan on installing slatwall instead of the pegboard in the garage when we put it back together.
                      • 3568
                      Its a woodworking site, right? Ditch the pegboard hooks and make fitted hangers that hold the tool like a snap on tool box fitted insert!
                        twistsol commented
                        Until I have more time, I'll have to live with the shame of using pegboard
                      • 9215
                      Maybe the older pegboard isn't quite as awful as the stuff I am using... I just know my little 23 ga pin nailer ripped it out...
                      Maybe I have shop gnomes running around in there. Might make some things make sense, like where the heck are my hole saws?
                        Just me
                        • 8437
                        You live in the HUMID 365-6 DAYS a year Houston TX area, twistsol lives in the sometimes months long FREEZE DRIED area of Minn. Might that have anything to do with it?
                          • 20966
                          There's two grades of pegboard and two grades of pegboard hooks. The hole size and spacing is the same but the heavy duty pegboard are twice as thick and needs really to have the heavy duty hooks which have longer peg hooks to anchor properly in the HD pegboard. The light duty hooks in HD pegboard don't allow the bottom stop to lie against the pegboard face and the tool hooks usually point obscenely towards the ceiling.
                          The heavy duty hooks are also made of metal that is about 33% thicker and a lot more bend resistant.
                          Oh, I found this: (see next post)
                            • 20966
                            Pegboard specifications (from the wikipedia article on pegboard)
                            For the B type its recommended to get heavy duty hooks.
Name:	pegboard specs.JPG
