Nwhomesteader, I think that most of the guys here that use 4" PVC piping are running the lower hp collector fans like the harbor freight and delta 110/220 volt units. This 4" PVC is usually the sch 10 thin wall drain pipe not the sch 40 rated for water pressure. Fittings for this 4" pipe is readily available at woodcraft, Rockler and highland fairly cheap. This size machine is on the borderline of needing 6" pipe and from what I've experienced this past year playing with mine full time is the 4" is probably the right size, regardless what the charts say. You can pull a lot of air through a 4" pipe. With a dust collector in the wood shop like mine that is subjected to fine dust, as soon as the filter starts loading up your efficiency goes away, rating your machine back down to where 4" pipe is the best size.
capncarl
capncarl
