What's your 2025 Shop/Project Outlook?
    • 3126
    What are your shop and project plans for 2025?
    Here is my list
    • Build my office Desk. Last February I put a piece of particle board on my current desk to determine the size and decided 2 meters is the length I need for my three computer setup.
    • Build a mortising jig since that will be necessary for the desk.
    • My other daughter also wants a Murphy bed for her house.
    • Replace the wire shelving in the pantry with built ins
    • Not really a project, but my shop computer is a 2015 laptop that has a failed display and nly connects to the external display about half the time so it will need to be replaced and I'm out of hand me downs so I might need to buy something useful.
    My Sawstop savings just took a hit with a $2700 repair to my truck, so barring winning the lottery, that is probably off the list for the year.
    Off my tailbone. I have heavy cleaning about 3/4 of the way done. Time to install the mini split, get the wide drum sander going, fix the plumbing for my DC as it got separated somehow, and get camping gear OUT of my shop and into the shed or camper where it belongs.
    Design done, I am having to maximize space in my home office for some additional business activities and relevant equipment and supplies. Making a set of custom shelves for said setup. Sort of like my former Tool stacker idea, but indoors, and housing graphics / office equipment and supplies for vinyl cutter, and sublimation printer OVER the table already housing a 15x15 heat press, and a mug / tumbler heat press.
    Finalizing design for a similar setup to house my 3D printers and the associated supplies.
    Fix the bed frame from the master suite (squeaks, has since it was new, they kept swapping the pieces out but never bothered to realize it was the mortise for the brackets was too shallow allowing slop in the joint...).
    Having an electrician come in and do an upgrade, run 2 added circuits to the office to supply power for the heat press and vinyl cutter. Plus added circuit for my 3D printers, and yes my main panel has the capacity for it.
    Dive headlong into the kitchen and bath cabinet refacing. Kitchen cabinet needs new doors, drawer fronts, and the sink base cabinet needs a new floor as the original particleboard one fell apart. Planning on something like Poplar raised panels as I want to paint my cabinets ultra bright white. My late wife always hated the idea, but I like it, and the choice is now fully mine.
    I have the measurements and templates I need to redo the "Kitchen" cabinet in the camper. Moving the fridge over to the passengers side and making the cabinet standing height so I can install an 85L fridge and off load the 45L model. This is going to render the sink and countertop useless with the pop top down, but allow me a much larger fridge, more space for the drivers seat to recline, and MUCH more storage in the fridge cabinet.
    Counter top for said cabinet, stock is prepped and waiting.
    Cabinet doors for the camper, simple rails and stiles with cedar panel filler. Roundover edges for safety but overall trying to keep it rustic.
      I put everything off until after full knee replacement in two weeks. Doc said I won't rehab as fast as most. I had full knee surgery 45 years ago reattaching 3 ligaments - before laparoscopic surgery. That will make for a different set of cuts for knee replacement.
      That said, I had a dozen projects for the spring and summer lined up. But I need to replace and rewire the attic lights first for LOML to find lost items and help her clean out the attic; Then remodel a bathroom. That will get me started for the year - probably in April or May.
      • Slik Geek
        • Dec 2006
        • 708
        • Lake County, Illinois
        • Ryobi BT-3000
        I just started to fabricate 38 kitchen and pantry cabinet doors today (Hard maple frames, baltic birch inner panels), and then 18 drawer faces. I also plan to build the permanent version of my drill press table. Then I need to finish topping my interior windows and doors with crown molding trim.
          I completed the easel and step stool for the Grand daughter for the Holidays.
          I don't have any concrete plan for anything... out of ideas.
          Repairs needing attention:
          Click image for larger version  Name:	image.png Views:	0 Size:	480.7 KB ID:	860177
          Click image for larger version  Name:	image.png Views:	0 Size:	684.4 KB ID:	860176
          The header for the garage door opener rail split after 30 years... have to get up there and fix that, kind of awkward with all the junk I have in the way. Yes it split and the bracket shifted 8 inches to the right. Should have used 3 screws originally in retrospect!
          I'm afraid to use the opener... the trolley's been manually disconnected for a while.
          Oh, yeah, probably have to help grandson#2 with Pinewood derby for scouts.
          Update: fixed. Got branded, too. Had to treat my grandson #1 who helped to Pho.
          Note the metal bracket now has all three screws!
          Click image for larger version  Name:	20250428_004321.jpg Views:	0 Size:	143.0 KB ID:	861159
          • JeffG78
            • 389
            • Sun City West, Arizona
            I haven't visited or posted here for a long time. I'm currently finishing up a bathroom vanity. I just need to paint the door/drawer fronts and finish the top. I made the vanity top from Arizona Ash and created planks from the wood so I could mix up the boards and give it a more random look. My plan is to distress/age the boards to mimic my shower tiles. I debated whether to use a vessel sink, but I decided to use a regular undermount sink. Once I have that, I will make a template and cut the opening.
            • jacobs
              • Apr 2024
              • 18
              The Murphy bed project for your daughter is such a nice touch too! As for the shop computer, investing in a new one sounds like the right move, especially with the display issues. On a related note, I'm also thinking about upgrading the windows in my home. I plan to explore Windows USA reviews to help me make a more informed choice before I buy. Their site offers a lot of insights that could guide me toward a good decision for the installation.
              • Jim Frye
                • 1364
                • Maumee, OH, USA.
                • Ryobi BT3000 & BT3100
                SWMBO just came up with a laundry room remodel. She wants overhead cabinets with a shelf to eliminate a little rolling shelf thing that fits between the machines. And then replace the current utility sink with a cabinet sink. If I can talk her into getting the cabinets from the same place that did the kitchen cabinets, my work will be much easier. As far as woodworking, I'm finally going to learn bowl turning. I hauled my little used lathe out and set it up. it is set up as a gap bed lathe to turn the bottom of the bowl. Note the black tube. The lathe has a 2 1/2" vac port on the end panel and the tubing connects with it for faceplate turning. Taking it slowly and planning each step. Also hauled my turning books out to reference what I'm doing.
ID:	860507 Click image for larger version
                Jim Frye
                The Nut in the Cellar.
                  • 3791
                  Must everything in the chop have to be moved or relocated every time I start a project?
                  1. Santa was good to me, now I must convert my miter saw station from a Hitachi to a Festool Kapex. I want to retain the lexan hood and its duct piping from the ClearVue cyclone even though the Kapex isn’t suppose to spew dust everywhere like the Hitachi does. It can be done but I’m not sure how.
                  2. I Spent the rest of my tool budget on a Shop Fox 20” helical cutter head planer so I could build a new built in entertainment center. ( everyone gets new tools for each home improvement project? Right?) The planer table raises and lowers so now my table saw and its outfeed table won’t work as for a planer outfeed table, so I have to rearrange more stuff.
                  3. Sell a lot of shop stuff I don’t use to recoup some of my tool budget.
                    twistsol commented
                    The Kapex dust collection is far better than most saws and is still the worst offender in my shop. I still haven't figure out how to get really good dust collection for it.
                  Build new cabinets for the camper van kitchen. Going to flip sides of the fridge so I can fit a 65L 12v fridge, finish the butcher block counter top. Remove the dinette since I never have it in seating mode, Improve storage under the bed and add a proper memory foam mattress...
                  Finish the master bath remodel.
                  Build new bed frames for the master bedroom, and guest room.
                  Install the mini split into the shop finally...
                  Anything else after that is just gravy...
                    • 3126
                    I've accomplished almost nothing on my 2025 shop list except replacing my shop computer. I picked up a Mac Mini M4 so that ought to hold for a computer in the shop for a decade or so.
                    I started the mortising jig and ordered the Microjig Matchfit bit and accessories, but haven't had any shop time to finish it.
                    • Jim Frye
                      • 1364
                      • Maumee, OH, USA.
                      The next shop project (after clearing up after the bowl turning project) is to clean the shop of several years of accumulated dust. This involves turning the ambient air up to 11, firing up the air compressor with a blast nozzle mounted, and running the shop vac while I work my way around the shop following the air flow of the air filter.
                      Jim Frye
                        I am rebuilding some yard carts, yard trailers, and wagons. I have a yard cart that is about 40 years old and the wood all rotted out. The frame is still good but the 4 prong T-Nuts and bolts were all rusted so much I couldn't save but about 5 or 6 sets. It is much like the picture below. I will post a picture of it as soon as I finish the tail gate. I changed out the air pressure tires for solid ones, which I love.
                        Click image for larger version  Name:	9120SFCzIBL.jpg Views:	0 Size:	252.5 KB ID:	861102
                        I also am working on a large wagon that had air pressure tires which I hate. They have to be aired up every year and need replacing about every 3 years. SO I bought solid tires & wheels from HF, but discovered after getting them home, that the wheels, while they fit the 5/8" axle, the wheels at the axle are wider than the axle space. The axle needs about 1/2 inch length for the wheels to fit. I found a good 5/8" round bar and cut 4 pieces 1 inch long and drilled them out to to near size of the axle threads and then used a tap to put a thread on the inside to accept a 1 inch long threaded bar. I have bolts the same size as the end threads on the axle and will cut them to size for the nut to hold each wheel on. In essence, I have extended the axles by 1 inch while it only needs 1/2 inch. I will add a 1/2" spacer on the inside of the wheel to take up the extra space. I will post a picture of the work when I finish it in a couple of days.
                        Same trailer as this HF Trailer except mine is from Northern Tools: https://www.harborfreight.com/1200-l...des-58473.html
                        I also added solid tires on an old Sears yard trailer made for their LT1000 yard tractor. I should be through with all my trailer fixer uppers, by the weekend and will photograph each. along with the work.
                          Getting more done not exactly shop, but bathroom reno done. Need to edge the walls / ceiling next, and build a mirror surround... My paint edging pad fell apart though.
                            • 3791
                            The one big shop project that I put off last year still needs doing, that is to pull the engine out of my 1990 Mazda Miata and give it a refresh. It still runs like new but it has an aggravating front main seal oil leak. I don’t take long trips in it so the oil level doesn’t dip down dangerously low but it does make a mess on the garage floor, and it needs fixing. I caused the oil leak in 2023 when I replaced the timing belt/water pump/belt tensioner and decided to replace the front main seal while I hade it torn down. The seal puller that I used has a screw that penetrates the seal while the slide hammer snatches the seal out, but due to the lack of room (meaning there is none) I was unable to get a straight pull and the screw gouged the crankshaft. I thought I had the scratch polished out but after reassembled it leaked. This time I’ll pull the engine out and disassemble the engine and let the machine shop regrind the crank, bore the cylinders and grind the valves. I’ll replace all the other car engine stuff and clean the engine compartment and stuff it back together. Before I start this project I’ll have to build up enough Tiny Trees, Mushrooms and Tables to hold my 2 stores till I get finished! Probably after the machine shop gets the engine I’ll have to roll the car out and build more Trees and Mushrooms before I get to put the car back together. Im not sure what the operating life of the HEPA air filters on my ClearVue dust collector is but I bet I have exceded it and they need replacement. Hopefully I can get that done this year too.
