Cutting Marine Ply Patterns
  • Woodboy
    • 96
    • Lakewood, Colorado.
    Building a stitch and glue kayak from plans which requires cutting a lot of 4 mm marine ply section pieces. I have a great Bosch jig saw which is not quite working as well as I would like, too hard to keep from minor wandering. Thought about a small electric skill saw, Makita, but you cannot see the actual blade where it contacts the wood - you have to trust the little mark at the leading edge, plus I have some mild curves to cut also. Actually, I am cutting 2 identical 4 mm each sections at once, plus a thin piece of Masonite on top, I hope to use as a future form. My actual size paper plans are glued to the Masonite.
    Has anyone ever done really precise cutting with a Japanese thin kerf push saw for a job like this?
    Any suggestions?
    "Life is tough, where a cup"
    Dennis Miller
  • Carlos
    • 1893
    • Phoenix, AZ, USA.
    Rip fence or long clamp-on guide? I use both with my 20v Dewalt circular for perfect cuts.
      • 3789
      I’ve cut plywood sections for boat building projects using a band saw and following up with the stationary belt sander to finish the edges down to the line. Inside the panel cuts were made with a jig saw with a fine blade and finished with the oscillating drum sander. Most saws won’t cut as smooth as I want for the finished joint so I go the extra step and sand down to my patern line. Sanding doesn’t add any more ttime to the job than you have already fretted away looking for the perfect cut.
      capncarl
        • 3789
        I wonder how Woodboys marine plywood Kayak turned out?
        • Black walnut
          • Aug 2015
          • 5514
          Yeah, wonder how? Thanks Carlos, good catch!
