Hmm...nice call, Loring. I see what you are saying...mpc mentioned that I might have a bit of trouble with doing the second cut on the other side of the board, given that I will be dealing with a bearing running along an edge that was just rounded off by the prior cut/pass with the router. SO -- combining that with what you are pointing out with the Skil bit...hmm. I can see where that bearing might be running "under the ridge," so to speak, on that second pass.
Hmm...I went to the mlcs site, and looked at their "non-premium" bits...not the Katana bits, and I'm not sure that one looks much different from the Skil, with what appears to be a similar gap above that bearing...
http://www.mlcswoodworking.com/shops...ound_over.html
I need to take a look at that bit of my dads, see if it's a 3/8" radius, see how sharp it is, run a piece of scrap, and see how it does. If it won't work, I may have to just spring for the premium bit...
I can also find some "full bullnose" bits, that would make the full rounded edge in one pass. Negatives are cost, and that all are 1/2" shank to get the 3/8" radius (3/4" diameter). I have not found a 1/4" shank bit that will do a radius larger than 1/4"...
Steve
Steve
LCHIEN
