Sticky Rubber parts BT3100
    • 22010
    I was gifted a 20+ year old BT3100 I cleaned up and gave to my son-in-law.
    I think it was bought in about 2005 or so and left in the box and eventually passed on to the man's son, who a few years ago assembled it mostly but never turned it on.
    So it has a lot of garage dust and been exposed to Texas heat for a few summers.
    He found all the key parts except the miter fence clamp, but fortunately I made a few recenly from Rod Kirby's old design and it works.
    The other weird thing is the handles for the rip fence and the elevation/bevel crank have gotten really sticky, a problem I never had with the BT3000. Have others had this issue with the BT3000 rubber parts and how do you clean them making them usable without feeling like you got your hands all sticky?
    Click image for larger version  Name:	image.png Views:	0 Size:	1.07 MB ID:	862717
    • 22010
    I consulted AI - CHatGPT - the following is its verbatim response:
    Good old Ryobi BT3100 — still a very capable saw. The sticky parts you’re describing are classic “soft-touch overmold breakdown.”
    On that saw the problem parts are:
    • Rip fence locking handle
    • Elevation/bevel crank knob
    Both are rubberized over a hard plastic core.
    The good news: they’re easy to fix and usually worth saving.
    Best Fix (What I Recommend)
    1️⃣ Strip the degraded coating completely
    You’re not really “cleaning” it — you’re removing the decomposed outer layer.
    What works best:
    • 91% isopropyl alcohol
    • Mineral spirits
    • Blue shop towel or microfiber
    • Old toothbrush
    Process:
    1. Remove the handle/knob from the saw (much easier).
    2. Soak a rag in alcohol.
    3. Rub firmly — the goo will start dissolving and coming off.
    4. Keep wiping until the surface stops feeling tacky.
    5. Final wipe with clean alcohol.
    If it’s really bad, mineral spirits works faster — then follow with alcohol to remove residue.
    You’ll end up with:
    • Hard plastic core
    • No stickiness
    • Slightly less “soft” feel
    But it will last indefinitely.
    If You Want Grip Back
    After stripping: Option A – Leave It Bare
    Honestly, many BT3100 owners do this. The knobs still function perfectly. Option B – Wrap It
    • Tennis racket grip tape (excellent feel)
    • Self-fusing silicone tape
    • Heat-shrink tubing (cleanest look)
    For the crank knob, heat-shrink looks surprisingly factory.
    Replacement Option
    Some BT3100 owners 3D-print replacement knobs, and there are still occasional parts floating around on eBay. But honestly, stripping the original is usually better quality than aftermarket replacements.
    What NOT to Use on These Parts
    • Acetone (can damage the plastic core)
    • Lacquer thinner
    • Vegetable oil
    • Silicone spray
    Why It Happened
    That era of Ryobi tools used a polyurethane soft coating that breaks down with:
    • Humidity (Hilo = rough on it)
    • Skin oils
    Once it starts, it always spreads — so stripping it is the permanent cure.
    If you’d like, I can also suggest a way to make the rip fence handle feel even better than stock.
    On the Ryobi BT3100, the stock rip fence handle works fine, but it’s small diameter and not very ergonomic — especially if you’re locking/unlocking it a lot while dialing in cuts.
    Here are upgrades that are genuinely better than stock, not just “fixed.”
    1️⃣ Larger Diameter Grip (Biggest Improvement)
    The factory handle is relatively skinny. Increasing diameter reduces hand fatigue and gives more torque with less squeeze. Easy Method:
    • Strip the goo completely.
    • Slide adhesive-lined heat shrink over the grip area.
    • Use 2:1 or 3:1 shrink for a snug fit.
    Result:
    • Slightly rubbery feel
    • Larger diameter
    • Clean factory look
    • Permanent fix
    This alone makes it feel like a higher-end cabinet saw.
    2️⃣ Tennis Racket / Baseball Bat Wrap (Surprisingly Excellent)
    This is my favorite functional upgrade.
    Why it works:
    • Cushioned
    • Textured
    • Excellent grip even with dusty hands
    • Cheap and replaceable
    Wrap tightly and finish with electrical tape at the ends.
    It’ll feel much more like a premium hand tool handle.
    3️⃣ Replace with a Star Knob or Clamping Handle (Mechanical Upgrade)
    You can upgrade beyond “rubber fix” and improve the ergonomics entirely.
    Many BT3100 owners replace the locking handle with:
    • Adjustable clamping handle (ratcheting type)
    • Large star knob
    These allow:
    • Easier re-positioning
    • Better leverage
    • Less knuckle clearance issues
    If the threaded stud is removable, you can measure it and match the thread size (often metric).
    This makes fence locking smoother and more controlled.
    4️⃣ Wooden Custom Handle (Best Feel, Most Work)
    If you’re a woodworker (which you are ):
    Turn a hardwood grip:
    • Drill center hole
    • Epoxy onto original core
    • Or tap threads and screw it on
    Walnut or maple feels fantastic and won’t degrade like rubber.
    Honestly, a turned hardwood knob feels better than the original ever did.
    My Recommendation (Balanced Option)
    For minimal effort + maximum improvement:
    Strip it → Add adhesive heat shrink → Slightly increase diameter.
    That gives:
    • Clean look
    • Better grip
    • No future degradation
    • 20-minute job
      • 3756
      Thanks for the nice instructional. I’ve had the same issue with some other handles before. I had a pint can of rubber screwdriver dip, can’t recall its name. I let it set for a couple of days and it was ready for more years of use.
      Here’s another project for you. I have a few Craftsman screwdrivers that have the clear with red striping/trim that get cloudy and fuzzy looking like they are covered in white mold. I wash the off and they clean off nicely but fuzz up within a few months. Curious that only a few Craftsman screwdrivers do this while the remainder of the set is unaffected.
        • 2807
        Thanks Loring,
        As always, your instructions are very complete.
        Oddly, I haven't had any sticky problems with my BT3100. The handle knobs on my Ridgid drill press and certainly a number of other objects (like those blue LED lights from Harbor Freight) have been a problem and I have been using alcohol to clean them quite successfully.
        Your instructions are quite thorough, and beyond just 'wiping' clean.
        Much appreciated,
          LCHIEN commented
          well, I got the instructions verbatim from ChatGPT. AI is getting pretty good.
        • 9523
        I've not experienced the stickiness with mine yet. But who knows. Maybe it got gooey before I got it...
          • 3110
          My wife had the same problem with her Volvo steering wheel, hard plastic with a rubber outer coating. We just wrapped it in leather (the steering wheel, not the Volvo) and problem solved. It might work and since it is a 3100 not a 3000, just about any color would be fine.
          • Jim Frye
            • 1343
            • Maumee, OH, USA.
            • Ryobi BT3000 & BT3100
            Had to go down to the shop and look at my BT3100. It’s a very early production unit that I received from Ryobi for evaluation when the saw was first released. The saw sits unused under the BT3000 and the tilt/elevation handle is dust covered, but not sticky. The rip fence has my shop built router table fence mounted on it. That handle is also dusty and not sticky despite being used fairly often. FWIW, the BT3000 handles are superior. Mine are from February of 1993 and are like new. I will say both saws have spent their entire lives in a basement shop, where the temperatures have always been in the lower to mid 60s.
            Jim Frye
            The Nut in the Cellar.
              LCHIEN commented
              I'm sure heat has a lot to do with the deterioration of the rubber compounds.
              This particular saw was in Texas heat for several summers in a garage shop that was uninsulated.
