Were it green and labeled FESTOOL, easily $thousands and people would lust over it
  • Fried Chicken
    • Jun 2024
    • 20
    • Texas
    • Craftsman 315.218290
    And i'm not even being hyperbolic here.
    I "collect" useful tools; I'm always scanning the market and will acquire things in anticipation of their future use.
    For me and my Craftsman Ryobi BT3000 that time has come now, and I've finally gotten around to using both the router and the table saw.
    I am floored. This thing is amazing, and were it green with FESTOOL stamped on it... $thousands, easily...
    I still need to finish accsesorizing it and setting it up as I'd like it.
    Yet there are those who are ignorant of its ability and argue vehemently that it is only a toy. Ignorance is bliss for them.
    • Jim Frye
      • 1364
      • Maumee, OH, USA.
      • Ryobi BT3000 & BT3100
      Blowing the BT3x00's horn, not mine.
      https://www.sawdustzone.org/articles...y-buy-a-bt3000
      Jim Frye
      The Nut in the Cellar.
      • tfischer
        • 2349
        I've been making dust with mine for over 20 years now. While there are times I wish the build quality were higher, and more times that I wish replacement parts were available (I'm probably one broken belt or fried motor from having to get a new saw... and I'm on my second motor) I love this saw and plan on keeping it as long as I can.
        • Jim Frye
          • 1364
          • Maumee, OH, USA.
          Ryobi sold over 600,000 of the BT3x00 saws. Parts are available if you ask here where to find them. I bought spare belts when I burned mine up shortly after buying the saw. I swear having a spare set is insurance. I also bought a spare set of SMT slides which have never been needed. I also have an unused BT3100 sitting under the BT3000 to use for parts if needed..
          Jim Frye
            Keep browsing eBay and yes even Amazon for BT3000 and you will find a surprising endless stream of replacement parts that ebbs and flows. I've been stocking up on the critical plastic and rubber parts so if anything breaks I have spares. $5 -30 bucks here and there a few times a year is cheap insurance.
            Here's what I think I have off the top of my head.
            belts (set of 2)
            SMT slides
            SMT table
            aux table
            Miter fence
            arbor nut, washers and bushings(2)
            handwheel
            I replaced the rear rip fence roller bracket with a metal one when mine cracked, I've since sold the plastic spare I had
            rear rip fence roller wheel
            • othermeans
              Handtools only
              • Apr 2025
              • 2
              I love my Ryobi BT3000. Wait for it...sorry no but from me. I have a small garage and it works perfectly for me. All the accessories you can add or make for it make me love it more. When I had a VW bug in my younger days a saying I heard alot was "I'll never sell my Vdub it needs me and I need it!" That's how I feel about my Ryobi.
                • 9568
                Aside from certain parts being discontinued, my only real issue with the saw is the aluminum top instead of cast iron, but that would have made the saw a LOT more expensive... so there is that...
                • Jim Frye
                  • 1364
                  • Maumee, OH, USA.
                  I've never had any issue with the aluminum table tops on the saw, nor any aluminum table on any tool. The bare aluminum can mark some woods, but I've waxed mine with a liquified paste wax and never had a problem. A cast iron top would also have made the saw a lot heavier and thus less portable.
                  Jim Frye
                    dbhost
                    commented
                    True enough, but VERY hard to use magnetic accessories on the aluminum tops...
                  Aluminum has its advantages and disadvantages.
                  Pros: Its light and inexpensive and doesn't rust; It is fairly easy to machine
                  Cons: it is softer than steel or iron and it doesn't have the heft which is useful if you have a machine that vibrates any; the weight of cast iron dampens out the vibration. It can leave marks but paste wax has made that a non issue.
                  On the whole I never miss a cast iron top or stamped steel wings on the BT3000.
                    twistsol commented
                    I've always interpreted the vibration dampening argument as "Our extra heavy top is good at masking vibration caused by our poor build quality and out of balance components." Doesn't seem like much of a feature to me.
                • dirtmover
                  • 21
                  • Ottawa, ON, Canada.
                  I've had my bt3000 since 1999 and still use it regularly. There was a high level of innovation in that saw but they really needed to raise the execution up a couple of notches. Too many weak design choices and easily breakable plastic parts. I've always felt I've had to baby it rather than being able to work it hard. Regardless it has been a great saw and coped well with most of what I've thrown at it.
                  The BT3x00 has a lot of design deficiencies that need to be addressed before it could wear the green badge of honour.
                  • Jim Frye
                    • 1364
                    • Maumee, OH, USA.
                    I bought my BT3000 in February of 1993 at Home Base for $500. It has been the best tool money I ever spent. It has never failed to do exactly what it was designed to do and with the jigs and fixtures I've made for it (articles), it goes beyond what many table saws can do. It can resaw 3 1/2" stock while my BIL's big 3 hp PM 66 can only do 3" stock. I burned up a set of belts a few months after buying it by trying to start the saw with the blade jammed into a new blank throat plate. The one and only fail for the saw. They will have to pry it from my cold, dead hands before I will part with it.
                    Jim Frye
                      • 3126
                      I tend to disagree with the OP. As an avid Festool user, what they have in common are innovative ideas and excellent precision. Where they differ is that Festool's are intended to be thrown in a truck and used on the job site, day in and day out while maintaining that accuracy.
                      I loved my BT300 and 3100 for the nearly 20 years I owned them, I did burn up a motor running dados for 9 hours straight for production project. It's a great saw if treated well, but doesn't stand for abuse. In the end, the two saws were worth far more than the $767 ($498 for the BT3000 and 269 for the BT3100) I paid for them.
                      Incidentally, 30+ years after the BT3x00 the Festool CSC 50 has some of the innovations Ryobi pioneered and they come with the same complaints because it is different. My favorite complaint for both is they are "just cheap plastic and aluminum."
                      • Jim Frye
                        • 1364
                        • Maumee, OH, USA.
                        I understand that all tools have pros & cons and if your pros outweigh your cons, then it becomes a tool worth having. I constantly remember my Grandfather's old adage "It's a poor workman that blames his tools".
                        Jim Frye
                          I have noticed a tendency over the years with the "thrown in a truck and used on the job site, day in and day out": With the very expensive tools, the workers are usually working very high end houses and businesses and with the expensive tools, they are very careful with the loading and tying down the tools to keep them in tip top shape. The cheaper the tool, the less the worker/owner takes in protecting the tool and the more lower end work he or she does. High end workers keep their tools organized and there is a specific place for each tool.
                          Unfortunately, the BT does and can produce consistent accuracy, but it does need to be treated as such. Its inexpensiveness lended itself to be treated as a cheap tool by many.
                            capncarl commented
                            Lee, you are correct! The few contractors that I have seen that use Festool equipment use Festool extensively. Their truck probably is a high top Mercedes van with sustainer cabinets down both sides of the van, so they don’t actually throw them in the trucks they gently place them in the proper bin. I wouldn’t be surprised if each sustainer bin isn’t fitted with sensor that will not allow the truck to crank if the tool is not in its bin. These are quality tools and should be treated as such, and are not used by fly by night contractors. I’ve heard that some high end general contractors will not use subs that don’t use Festool or similar.
