BT3100 Maintenance-Best way to access saw parts
I would like ti see CWSmiths view on this . . . BUT . . . Owners manual often/usually comes in tech talk that is over the head of the average person. I can't tell you how many times I tried looking up things in my wife's Prius manual and in my Camry manual. The index is the pits. It took us an hour and a thesaurus to look up different related words to find out how to re-set the "change Oil" warning light. It was not under maintenance, or oil change or warning lights. When it comes on when you are in the middle of a long trip, it needs to be reset so that we can continue to drive until we get to a place and time that we can have it changed.
Owners manual - 4 different ones for one vehicle? Add to that the words/index they use - are not common folks terms either.
That reminds me when I got to Japan and was learning Japanese and wanted to do Japanese Language on a computer - here is what I heard numerous times at a couple of computer clubs in Tokyo: You have to know and understand computer lingo to operate it. There is no training manual on terminology - you just have to know it! I promise you I heard that numerous times. A real catch 22 to learning how to use or operate a computer. (I was also amazed to find out that I could out type my Japanese friends in the Japanese language also. At first I just thought they were using flattery on this "gaijin" and finally I called them on it. Then they said: We do not take typing I school; we do not have a single unified keyboard like you Americans do, therefore (at that time in the late 80s,) very few knew how use a keyboard.)Last edited by leehljp; 07-21-2019, 07:39 PM.Hank Lee
Experience is what you get when you don't get what you wanted!Comment
Electrical Engineer by day, Woodworker by night👍 1Comment
Hi Folks,
I just wanted to thank a few folks who provided useful advice. Everything is lubricated and the blade lifts like it was brand new (at least what I imagine how a new BT3100 would operate new )
Loring thanks for the helpful advice in this post and in the FAQ. The details in that FAQ are incredible and all of us owe you a debt of gratitude. I was able to see in the operator's manual the mention of the elevating shaft and bevel gear that needed lubrication but was not able to locate them without removing the side. I also saw your instructions and parts list in the FAQ and once I removed the sides the location of everything was obvious and I was able to access everything to follow your directions.
Jim, as you probably see from above, the removal of both sides was critical for me to complete this task. Thank you for the critical advice! In retrospect, it should have been obvious that those were access panels, but it wasn't at the time. BTW, my operator's manual (BT3100 version 3-28-06 rev01) mentions nothing about removing the sides anywhere in the document (p36 is about adjusting the sliding miter table). I have read it multiple times over the years and thought it was unusually well written compared to others I have read (or if I could even find manuals when performing my old woodworking tool restorations).
Hank, that was my experience as well. Once those sides came off, everything else was simple.
Capncarl thanks for your posts as well.
Thanks again and have a good evening,
Rob
👍 1Comment
capncarl Thank you! I do understand what you're saying and I do think it is important. I also see that in this thread the OP was given options and ideas to do what he was seeking. Then I see topic creep to the subject of manuals. Although it has been a long time since I have done so I do not recall that the owners manual for the BT3K detailed cleaning, inspecting, and lubing the shims.
I believe we are so much more than most of the other forums I visit in that folks who reply here have been there and done that. On another forum I have read so many times folks offering advice based on what they had read on the same forum and decided that is how they would do it when the time comes in some future time.just another brick in the wall...
Boycott McAfee. They placed an unresponsive popup on my pc.Comment
I created a YouTube video that documents puting in replacement shims that goes a long way to describing disassembly and reassembly.
https://youtu.be/i5XBkmYItx0
Sent from my ONEPLUS A6003 using Tapatalk
👍 1Comment
Just a couple of observations. Why did you totally disable the saws riving knife? Do you use a guard? Do you have a splitter installed? Your saw looks unsafe to me.
Have you tried other methods to access the shims? It’s not clear in your video why it is necessary or even a “better idea” to nearly disassemble the saw.
You are the only person advocating the use of grease for lubricant on this saw. Perhaps you could think about why that might be the case. Using steel wool to clean or polish aluminum leaves shards of steel imbedded into the aluminum, were you aware of this? Liquid cleaners or solvents work just fine and have no chance of harm to the saw parts. The correct lube for this saw is a dry lube. There are plenty of options. None of which will attract sawdust.just another brick in the wall...
The steel wool serves the same purpose as a solvent. Because of the relative hardness of the rails I see no issue of embedding steel wool there.
Thanks for the feedback and correction.
Again, I just hope the takeaway is that anybody can get their table saw back in working order with a little guidance.
Tim
👍 1Comment
Footer Ad
