Ryobi 12in Drill Press - Clearance (Discontinued)
    Not much of a bargain yet, but once they're gone... There doesn't appear to be a replacement in this size from Ryobi/Home Dept, looks like they'll only be carrying the 10in model.
    Picked one up tonight for $152 (regularly $179 here). This benchtop model has the 3+ inch spindle travel. My HF 8inch DP continues to run strong 10+ years later, but it only has a 2inch spindle travel.
    The bench tops are a handy DP. Price sounds good for one with a 3" travel.
      • 22033
      lists for $179 w/free shipping on the HD website.
      3+ inch stroke is good for a 12" unit (but this in not listed in the on-line spec, I'm taking your word for it)
      12 speeds (500-3000RPM), 5A motor (= 600W ~1/2-3/4 HP?).
      • JoeyGee
        • 1509
        • Sylvania, OH, USA.
        I've had my eye on this one for awhile. Now I don't know if I should snag one now, or wait to see if they go down more...
        Thanks for the heads up.
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          buy it now and if the price falls in the next 90 days, return it and rebuy the same unit for the lower price.
            There is a heading called 'Specifications'. If you click on that, you get more details. Among the details you'll see a spindle travel (stroke) of 3".
            Amperage (amps) : 5 A
            Assembled Depth (in.) : 26.80 in
            Assembled Height (in.) : 10.8 in
            Assembled Width (in.) : 18.5 in
            Bench & Stationary Tool Type : Drill Press
            Bench or Stationary : Bench
            Built-In Light : Yes
            CSA Listed : No
            Chuck Capacity : 1/2 in
            Color Family : Blue
            Cord Length (ft.) : 10
            Depth (in) : 18.50 in
            ETL Listed : Yes
            Height (in) : 10.80 in
            Item Package Type : Cardboard Container
            Item Weight : 91.21 lb
            Manufacturer Warranty : 3 Year
            Maximum speed (rpm) : 3000
            Minimum speed (rpm) : 500
            Number of Speeds : 12
            Power Tool Product Type : Bench & Stationary
            Product Depth (in.) : 26.8 in
            Product Height (in.) : 10.8 in
            Product Weight (lb.) : 95.9
            Product Width (in.) : 18.5 in
            Reconditioned : No
            Returnable : 90-Day
            Spindle Travel : 3 in
            UL Listed : 1-UL Listed
            Voltage (volts) : 120 V
            Width (in) : 26.80 in
            Work Light : Yes
              • 22033
              CSA Listed : No
              Color Family : Blue
              ETL Listed : Yes
              Reconditioned : No
              Returnable : 90-Day
              Work Light : Yes
              I stand corrected - missed it the first time. Guess i was in too much hurry.
                Here it is, with my HF table attached. Had to modify the table because the DP's round table was larger than allowed for the bolt placement.
                New horizons for me to explore: 12.5in from chuck to lowest table setting (my little HF DP only allowed 7in.). And with the 3in spindle/quill travel, I should now be able to drill my pen blanks without having to do it in two steps (formerly having only 2in, I had to stop, raise the table, and finish.)
                  That's a nice looking drill press. That extra capacity is just what you needed. How do you like the HF table?
                    Thanks Mike. Its substantially larger overall as well. My HF was 22in base to cover, the Ryobi is 35in. The HF table is good for my hobby use, probably not up to production requirements, but decent for the 20 bucks paid.
                    • duncsuss
                      • Oct 2009
                      • 138
                      ... I should now be able to drill my pen blanks without having to do it in two steps ...
                      This should be a real time-saver for you. I'm in the same you were at -- just 2" quill travel. I'm very tempted by the idea of a 3" plunge
                      • JoeyGee
                        • 1509
                        Awesome. I just came here to ask about the overall distance from table to chuck, and you answered it already. That has been my only real complaint about my current Craftsman 8" DP. I have the same HF table. I think someone is telling me to go buy this DP...
                        Thanks!
                        • toolbelt diva
                          • Oct 2004
                          • 202
                          • Houston, TX, USA.
                          • Ryobi BT3100-1
                          Darn! I just bought the 10" a month ago (can't find the receipt at the moment), but at least they accepted a HF 20% off coupon when I bought it.
                          Rita
                          • duncsuss
                            • Oct 2009
                            • 138
                            There's a new 12" DP sitting in the trunk of my car ... new toys to play with when I get home from work tonight
                            No price reduction for clearance, but with a HF 20% discount coupon, total was $152.15 including tax.
                            Thanks for the heads-up on this one!
                              Congrats on your acquisition. "Requires some assembly", and use the instructions in the book, not the quick sheet. And make sure you put the bar with the gear teeth on it so the unthreaded section is at the TOP or the table won't lower all the way and you'll have to disassemble to correct - and that head assembly is not light (DAMHIKT).
                              Also - don't pull your hair out looking for the 15w candelabra-base bulb. Buried in the book in fine print, is says "Bulb not included".
                              Hope it serves you well.
