Jet Cabinet Saw $753.97 - 3hp Xacta Fence
I am in the same boat, or a similar one anyway--after sending them a bunch of emails and talking to them on the phone to cancel the original order, they themselves decided to "recall" the shipment (I have it in email) and so I didn't have to refuse it, but I don't see my money coming back yet either! Sent them an inquiry about it today; let's compare notes later.
Unlike the rest of ya I am in no hurry to get this huge thing on my doorstep--don't really have a place to put it yet!Never met a bargain I didn't like.Comment
Its soooo nice.
Cut some 4"x4" olak beams it cut them like a hot knife through butterEvery tool you own is broken, you just don't know it yet :-)Comment
Got my refund today for the original 30" order.
They refunded the $750 AND the $150 for Shipping!!!!!Every tool you own is broken, you just don't know it yet :-)Comment
So did you mount the router on the inboard end and put a cross-piece under the table to attach the legs? I went to assemble mine the other day and there was no fence rail hardware (and the extension table was chipped). WMH is sending the replacement parts, so hopefully tomorrow I'll be up and running.Comment
I think so...basically I flipped the extension table around so that the router insert is on the closer side to the blade (from some good advice from Larry). I then glued and screwed the ripped 2x4 piece on the underside on the far right end of the table, allowing the legs to be mounted to the side of it and sit properly inside the base...So did you mount the router on the inboard end and put a cross-piece under the table to attach the legs? I went to assemble mine the other day and there was no fence rail hardware (and the extension table was chipped). WMH is sending the replacement parts, so hopefully tomorrow I'll be up and running.GaryComment
That looks like the best way to me, too-- easier than adding a piece of angle to the end of the base, and you have more table to work with for the router.I think so...basically I flipped the extension table around so that the router insert is on the closer side to the blade (from some good advice from Larry). I then glued and screwed the ripped 2x4 piece on the underside on the far right end of the table, allowing the legs to be mounted to the side of it and sit properly inside the base...
So now the $64K question-- how did you align the splitter? I'm spoiled; compared to the BT3K, there is high vacuum in this design. The two allens inside the cabinet are a PITA to get to, esp. with the blade on for alignment, and the outside shaft rotates when you adjust the inside bracket.
Edit: Never mind-- procedure is pretty straightforward. The allens in the cabinet are still a major pain, though.Comment
Agreed...so far, thats the only thing I miss about my BT3K is the riving knife. I'm not a fan of the splitter design. I'll post seperately in Tool talk to see if anyone has any solutions...So now the $64K question-- how did you align the splitter? I'm spoiled; compared to the BT3K, there is high vacuum in this design. The two allens inside the cabinet are a PITA to get to, esp. with the blade on for alignment, and the outside shaft rotates when you adjust the inside bracket.
Edit: Never mind-- procedure is pretty straightforward. The allens in the cabinet are still a major pain, though.GaryComment
Attention: if you want to buy or already bought the Delta mobile base it is now on sale 20% off. Amazon should reduce your price already paid.
http://www.amazon.com/Delta-50-289-M...d_i=1000093181
$76.Never met a bargain I didn't like.Comment
Wooo-Hooo . . . my free blade shipped today a few weeks a head of schedule. Hopefully my saw will ship well a head of schedule.Comment
WOW can't tell you how great this saw is. Did get the 50" extension with the router lift. This saw is incredible, accurate as **** and makes wood working a pleasure
I am building cabinets for our kitchen and the saw is more than I could have expected. Thanks Jeff for the original post!!!
Last edited by Woodwerker; 09-16-2007, 09:35 PM.Every tool you own is broken, you just don't know it yet :-)Comment
Glad you got yours! I ended up with 5hp Delta Uni X5 I caught on sale because my Jet (which one of the first ordered) would never ship!WOW can't tell you how great this saw is. Did get the 50" extension with the router lift. This saw is incredible, accurate as **** and makes wood working a pleasure
Those are great saws and was a once in a life time deal.Comment
