Maximum Width and Depth
Hey Jeffrey,
According to the manual, the maximum width is 32" and the maximum depth is also 32." A note is also added: "1. The dimensions listed are approximate measurements taken at the lowest outside corners of the leg stand." The maximum weight is 300lbs. I have one on a table saw that weighs about 200 pounds and it works very well.
This current lift is actually called the Herc-U-Lift Plus and replaced the original Herc-U-Lift and the current one (Herc-U-Lift PLUS) model is probably what you are referring to as the heavy duty. The model is AC9950. In an earlier post, mpauly listed the SKU as SKU# 352-522. Hope this helps.
Richard
Addendum after Originally Posting this:
I noticed that the diagrams in the book do not agree with the chart (for the universal leg set made by Ridgid) that I quoted above; one diagram shows a lift adjusted for a miter saw with a width of 37.25 inches - bigger than anything on the chart and also a RA Saw with a 35" depth, also bigger than anything on the chart. There is also a lathe shown with a length of 58 inches but it requires accessory tube set AC9951 which must be purchased separately. Sorry if I caused any confusion.
Richard
