How Far Can Level and Flat Be the Same?
    Originally posted by leehljp
    Loring, I appreciate the research you put in. In one estimation I had about an inch and on another I had nearly 3 and that is with my guestimation, which is never precisely accurate.
    Now to throw a kink into the discussion - how accurate is it for the earth at any given point? By that I mean that the earth is not exactly a pure sphere. Kinda like Mt Everest is the highest mountain in altitude from sea level but due to the bulge at the equator, the highest point above Earth’s center is the peak of Ecuador’s Mount Chimborazo, by about 2000+ meters.
    https://oceanservice.noaa.gov/facts/highestpoint.html
    I don't think that would change your calculations. I will keep these and show him what he needs to shoot for in leveling!
    .287 is .574 (1/2 inch) at 2000 ft on a fairly good sphere. And how accurate is his leveling ability?
    This was not a problem 15 years ago as rice fields in flat lands were still terraced. But with micrometer locating GPS leveling of the last 10 years, machines only have to level a field once for years to come, and have a single levy a foot high in a 1/2 mile by 1/2 mile square, or 1/4 of a square mile.
    I'm just intrigued how farming has changed in the last 10 - 15 years and how scientific it has become.
    • Half a million dollars for a single cotton picker!
    • One person can drive/control two huge machines at the same time;
    • machines don't deviate more than a millimeter on a path a mile long. Stopping on a "dime" is so old tech!
    Thanks for everyone's input!
    Hank, its not a straight slope at distances of more than a few feet! You cannot double the error from 1000 feet to get the error at 2000 feet.
    To begin with over if you are level at the middle, 1000 feet to the left will be down .28 inches and 1000 feet tot he right will be down .28 inches. You have a crown in the middle that is .28 higher than at the ends. To spread water evenly, then you need to raise the ends and the space in between by no more than .28 inches.
    If you are level at some point and want to go out 2000 feet to one side then look at my chart that includes 2000 feet... it says the end point error will be about 1.25" low. even though 1000 feet it was only .28" low.
      • 3791
      My answer to this question is with a question. ( How Far Can Level and Flat Be the Same?) Is a curved surface ever level? How long of a piece of the surface of a sphere flat?
      • Carlos
        • 1893
        • Phoenix, AZ, USA.
        The earth is flat, everyone with a brain knows that. The manufacturers of the level systems are in cahoots with NASA, and they curve/adjust the levels to make it seem like there's a curve. Get educated! You can start by joining the Flat Earth Society, which has members all over the globe.
        https://wiki.tfes.org/Flat_Earth_-_F...sked_Questions
          • 3126
          Glad someone finally brought that up. Every picture I've ever seen of the earth, including all the ones from NASA, have all been flat.
          • tjoosk
            Banned
            • Aug 2019
            • 10
            Very interesting story you related. At a latitude of 30 degrees north (not far from extreme southern Mississippi), an online calculator told me that the circumference of that circle of latitude is 21,583.3662 miles. The radius of a circle of that circumference is 18137340.2538 ft. The drop for a tangent (level) line at that radius 1,000 feet away (using straight line to make this simple and approximate, not the curved line of the earth) may be calculated by:
            SQRT ( radius^2 + 1000ft^2) - radius, which is SQRT( 18137340.2538^2 + 1000^2 ) - 18137340.2538 = 0..02756 ft, or 0.33 inches (approximately 5/16").
              It is not flat at any distance, there is an immediate curve, small as it may be.
              But, if you have a tolerance which you are willing to call flat, then if you tell me you regard flat as being 2 inches, then I can tell you a distance in which the earths curvature is less than 2 inches, that will be flat, to your specs.
                • 3791
                You have to figure, if you are using a water bubble level, that water tension goes into effect. Now some of you higher educated peoples xplain what that means!
                It’s raining and Water is beading up on the roof of my car. It’s not flat,,,, so how is this happening?
                  Equiporential gravity well.
