yet another hypothetical idea
  • pierhogunn
    • 1567
    • Harrisburg, NC, USA.
    Okay, here is one to test the broad base of knowledge here on the board:
    How would you dig a 60' in Diamater, 60' deep hole?
    Monty Python's Flying Circus
    Dan in Harrisburg, NC
  • Copper
    • 343
    • Madison, WI.
    I would never try to dig a hole that big. You did mean 60 feet right? It would take quite a bit of heavy machinery to do that.
    - Dennis
    "If your mind goes blank, don't forget to turn off the sound." --Red Green
    and yes, it's a potato.
    • Sam Conder
      Woodworker Once More
      • 2502
      • Midway, KY
      • Delta 36-725T2
      With a 120' shovel?
      Sam Conder
      BT3Central's First Member
      • catta12
        • Jan 2008
        • 250
        • Reno, NV
        • BTS20R
        .........c4................
        If you can read this you assembled wrong.
        Alan
          Aim a dead satellite at the spot and accept any error...
          • Mr__Bill
            • 2096
            • Tacoma, WA
            I can think of several ways, especially as the hole was not specified for shape.....
            invite a small asteroid to visit
            drill hole 60' deep and insert proper sized explosive, ignite said explosive and run like .....
            divert small stream to location and start a spiral flow of water
            very large carpenter bees
            tell some 13 yro boys you stashed your porn collection down there
            perform radioactive experiments on a few gophers, release mutant giant gophers at location.
            buy a dragline and play with it
            or....
            subcontract
            bill, on the sunny oregon coast
              Phase 1) Go to a fat farm...
              Phase 2) Bore a 4" hole, 60 feet deep...
              Phase 3) Toss in a candy bar...
              Phase 4) Stand clear...
              • Alex Franke
                • Feb 2007
                • 2641
                • Chapel Hill, NC
                I think Roy Underhill has an antique 60' hand auger.
                • jackellis
                  • 2638
                  • Tahoe City, CA, USA.
                  I'd hire someone else to do the job, assuming there was a good reason for digging a hole like that in the first place. If the hole is square (meaning a cube 60' on a side), that's 216,000 cubic feet or 8000 cubic yards of dirt to move. Enough to fill something like 900 concrete trucks.
                    I would prefer an above ground shop. But, this question isn't that hypothetical. I would dig that hole in my front yard if I thought there was gold down there, like this guy.
                    • RAFlorida
                      • 1179
                      Thanks CMan for the insight.
                      We now know why Dan wanted that info. If you hit the gold vein Dan, let us know so we can dig too!
                      • gjat
                        • 686
                        • Valrico (Tampa), Florida.
                        Actually, not a bid deal. You would use a track hoe and have leave a ramp to travel back out, excavating the ramp as you work back out. I'd have to work it out, depending on the foot print and depth reach of the hoe, some of the ramp would have to be backfilled to acheive the final dimension.
                        • shoottx
                          • May 2008
                          • 1240
                          • Plano, Texas
                          I would just cut a slice off of this mine and install it.
                          http://www.usmra.com/photos/bigpit/
                          • rjwaldren
                            • 368
                            • Fresno, CA
                            No problem, get me my sand wedge - Mind you, there will be spire with a ball perched undisturbed on top of it left in the middle.
                              • 22109
                              start in the middle, remove everything that doesn't look like a hypothetical hole.
