Elect. Outlet which way up?
  • Mr__Bill
    • 2096
    • Tacoma, WA
    It seems that it no longer matters which way is up, now you can have it anyway you like. They seem kind of neat but expensive and another thing to go wrong.
    Found at Amazon
    Bill, on the Sunny Oregon Coast
    • 9560
    You know... The GFCI in my master bath is upside down... I realized that after I installed it... I don't want to go back and fix it...
      My understanding, in Canada, the ground is supposed to be up. (some commercial regulation I saw)
      Here it doesn't matter, the most important thing, is to make it some standard that you know. (seen all up, all down, and one house the owner had the ground facing the direction the wire came from)
      • Alex Franke
        • Feb 2007
        • 2641
        • Chapel Hill, NC
        You could use a small motor and wire it up spin around while not in use... or heck, even while in use. That would be fun!
        I always thought it would be cool if the receptacles were recessed within the wall allowing you to close (and even lock) the cover with only the cords exposed. But there's probably some building code against that...
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          I read somewhere that 20 amp circuits were often installed ground up, and 15 amp circuits with the ground down. Don't know how true it is though.
            I install all mine with the ground down. I don't know why, other than I've always done it that way. I have read the 'proper' way is ground up.
            • Slik Geek
              • Dec 2006
              • 708
              • Lake County, Illinois
              • Ryobi BT-3000
              I have seen many installations with the ground down. Apparently the National Electrical Code doesn't have any rules regarding proper positioning of outlets. (I haven't seen it in my looking through the NEC, but I wasn't making an extensive search).
              The rationale behind the recommendation to install with the ground on top (when installed in a vertical orientation), or with the neutral, or wider blade on top (if the outlet is installed in a horizontal orientation), is based upon improved safety when a metal wall plate is installed.
              When the wall plate screws are removed (for whatever reason), and the outlet is "live", if the metal plate falls down onto a loosely connected plug, (so the blades are exposed), it's best that the metal plate doesn't become "hot". With the ground, or the ground-referenced neutral on top, the plate will contact those terminals and will not become "live or hot".
              If the outlet is installed with the "hot" terminal on top, this scenario will result in either a short on the plug blades by the metal cover plate (with the accompanying bright flash and molten metal), or will result in a metal cover plate that may contact the "hot" blade and become a shock hazard.
                • 22084
                it only "looks right" to me with the grounding hole down.
                gives it that surprised face look.
                • Tom Slick
                  • 2913
                  • Paso Robles, Calif, USA.
                  • sears BT3 clone
                  It used to be common to install a receptacle ground lug up if it were on a switched circuit. about 7-8 years ago NEC spec'd all commercial installations to be ground lug up. I don't think it is code for residential...yet.
                  EDIT: apparently the info I was given about ground lug up is incorrect. the manufacturers recommend them to be installed ground lug up but it is not a code requirement. makes sense considering you can install receptacles sideways and they are still compliant. Also IEEE standard 602-1996, section 4.2.2 recommends ground lug up.
                  • BerniePA
                    • 377
                    • San Tan Valley, AZ
                    • Grizzly 0575
                    Speaking strictly residential, I always went with ground lug down unless it was a switched outlet and then the ground lug was up -- but then, I'm only a retired telephone guy, not an electrician!!
                    Bernie
                      I once read a comment by a guy that installed them with ground up that it is safer because if the plug comes loose, and something falls on it, nothing will happen. But if ground is down, a metal item falling on a slightly unplugged plug can short the hot and neutral.
                      Sounded kinda far-fetched.
                      • Gator95
                        • Jan 2008
                        • 322
                        • Atlanta GA
                        • Ridgid 3660
                        Originally posted by cgallery
                        I once read a comment by a guy that installed them with group up that it is safer because if the plug comes loose, and something falls on it, nothing will happen. But if ground is down, a metal item falling on a slightly unplugged plug can short the hot and neutral.
                        Far Fetched, but possible. DAMHIKT.
                        • Larryl
                          • 284
                          • Lorena, TX, USA.
                          • Grizzly G0478 Hybrid
                          When I had my shop built I was trying to save a little labor time by installing the box and receptacles, all with the ground down(just looked right to me). The electrician installed the panel and the 220 wiring, and then changed all the plugs to ground up. Of course I was billed for the extra labor.
                          • stocktr8er
                            • 63
                            • Midland, TX
                            My dad (being an electrician in his youth) asked why the outlets were being put in upside down during construction at the school he now works at.
                            Simple answer from installer: if you step on a cord, the ground terminal will pull out of the outlet as opposed to bending or breaking off.
                            Curtis
                            • eccentrictinkerer
                              • Aug 2007
                              • 669
                              • Minneapolis, MN
                              • BT-3000, 21829
                              My friend, Ric, runs the Pro Desk at a local BORG. He wired all his outlets 'ground-up'. When the city electrical inspector showed up he asked him why he had put the outlets in upside-down.
                              Ric grabbed the 'How to wire your home' book that showed every outlet wired installed 'ground-up'! I was surprised that the inspector didn't realize that there is no code pertaining to that subject (well, not really surprised ).
                              I'm also one of those who thinks that 'ground-up' just doesn't look 'right'.
