Small Padauk Platter
    Got another question. I've seen green wood turners let their blanks sit for months to continue drying out. This blank was dry already so you can just turn it to final shape in one shot and not worry about acclimation?
      • 22106
      Very nicely done You tube instructional video, Bill.
      Was that the first one?
        Paul, to directly answer your question about my dry blank for the platter - yes, it was dry enough turn in one shot. Even so, there are stresses in wood that cause movement to be considered in the turning (same reason we use splitters and riving knives on the tablesaw). For example, on the rim of the platter, I had a tiny amount of movement where it is thinnest - this is why I subscribe to turning and finishing "as you go" from the edges in, without going back to the edges once done, as opposed to inside out; a veteran turner (don't recall who) demonstrated how if the inside material is removed and the edges "move" and are no longer perfectly flat (could even be slight, not enough for the eye to see), the tool will "skip" between the high and low spots. This is especially critical on "winged" forms. So with bowl and platter forms, I do shaping and finishing cuts on the edges progressively inward, about half way into the vessel, before removing the bulk of the interior. For sanding, I slow the lathe enough that my sanding pad with riding up and down on low/high spots, without skipping.
        For the question about green wood, it can be (1) sealed and left to dry before turning, (2) "rough" turned partially when green then sealed and left to dry before finishing, or (3) turned thin to final form. Each one requires a little different handling to achieve desired results (like stability or warping), and reduce undesirables (like splitting and cracking). My personal preference is to let the wood dry before turning.
          Thanks Loring - yes, video 02 was the first project video, and hope to have videos up for a bowl and a candle holder soon.
            That is beautiful Bill!
