anyone know much about flap sander attachments for drills?
    • 22108
    mop sanders, flap sanders,
    So many different kinds
    Any advice for small bandsaw/scrollsaw cleanup? small wooden toys and stuff?
    Click image for larger version  Name:	image.png Views:	9 Size:	457.0 KB ID:	863143
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    Had one of the flap wheel sanders hanging in the pegboard for over a decade. I was underwhelmed with its performance when new and that’s probably why it’s been hanging on the wall for so long unused. I prefer wire wheel brushes for metal, and sandpaper with a backer for wood.
    Jim Frye
    The Nut in the Cellar.
      • 3128
      I have a couple of them 120 and 240 grit. I thought they would be useful for sanding profile trim, and they are ok for that, but the profile will lose some definition as you are sanding it. I no longer use them on anything wood and chuck them up into the drill press to initially clean rusted metal parts.
        Mop sanders are used often in some scroll saw works, and in certain situations - highly praised.
        In general, all the types regardless of grit are not as aggressive as the inexperienced expects - just my thoughts, experience and reading others results. For me - Back to different traditional sanding tools, both motorized and by hand.
        • mpc
          • 1018
          • Cypress, CA, USA.
          • BT3000 orig 13amp model
          I've only used flap wheel style... long ago. Imagine needing to cut an arc shape into the face of a board - something easily done on a band saw. But not easily done when one does not yet own a band saw. I used a dado stack in the BT3 to make a series of overlapping dados of various depths: shallow on each end, deepest in the middle. So I had a stair-step shape that needed to be sanded into a smooth arc. I tried a flap style wheel and it worked well - buzzing those steps into something reasonably smooth. I found the 60 (or was it 80?) grit wheel that I used cut quickly. It also wore somewhat quickly too; I remember I needed several wheels to make the two arch shapes. I used a corded drill back when corded drills could run at fairly high RPMs - much faster than cordless drills and most corded drills sold today. 3000 RPM perhaps? The sanding wheels I used were 3 or 4 inches in diameter and about an inch thick/wide if I remember correctly.
          Lots of dust got flung into the air too. I would not consider a flap wheel sander on a high speed drill for "sanding up to the line" as control was somewhat iffy at times. I didn't have a good workbench with a vise at the time either - just F-clamps holding the workpiece to the top of the BT3 if I remember correctly. Nor did I have a drill press. I think it would be easier maintain control hand-holding the workpiece past a drill press mounted flap sander.
          mpc
            I would not consider a flap wheel sander on a high speed drill for "sanding up to the line" as control was somewhat iffy at times."
            AGREED! A regular drill is the wrong tool to use with mop type and even any of the type Loring posted in the OP. (Sorry, this just came to me as I was reading mpc's post)
            I almost forgot that bowl and some vase turners use those sanding disks too. But they use a different type of "drill" so to speak. Here is the type of drill best used with those type sanding wheels TO BE EFFECTIVE:
            https://www.amazon.com/Hoteche-Electric-Variable-Forward-Reverse/dp/B0D69KQW2M/ref=sr_1_45?crid=16FY5AD48O0AM&dib=eyJ2IjoiMSJ9.U_ KCV2v6JX-KdpwkUaolWUm2m7a0AWlJyImgu9ldrQ-Q_XDu4fL9E-8PjaBf5qKdDsDB9-2jz-W09ERGn-8wiJNSUuyhteg8ZVxDIjvy8l1V32prrIHRJKboXFNdfoLqOT42 1gjZQAT31la_rBCDGye_MBnDh5S1t9KzjOrVYinXoGaAbmDORl o1tbU145nrHX3Hj37FNelf9IdjaP4TormdYUhDkwhqHT9clGsk pIK_UFGf4evLn7IaIQRmUtI39WgPwvX_NPb2iEWD7qB9bmJxUA v-uvziJCh36s7zgfk.R41FGBLqsMwPVWgCz-Fm3czB4ljvgrOzBeiy2O7tAtw&dib_tag=se&keywords=Neik o+right+angle+drill&qid=1778024928&sprefix=neiko+r ight+angle+drill%2Caps%2C211&sr=8-45
            I have one of those under the Neiko brand and used it when I was in Japan and made bowls - when I wanted something different from making pens. I don't know What brand bowl turners use now and could not find one on Amazon other than the one above.
            I have seen a couple of Angle Grinders with them, and while not paying attention to the angle grinders, I'm thinking they must have had Variable Speed.
            FOUND Another one on HF's website: https://www.harborfreight.com/35-amp...ill-57148.html
            • Jim Frye
              Jim Frye commented
              The flap sander I have was used with my Makita 1/2 inch variable speed drill, which has a max. rpm of 200. Still did not like the performance.
          • d_meister
            • Feb 2009
            • 262
            • La Conner, WA.
            I have a collection of these types of wheels that have been on display with their 1/4" arbors plugged into pegboards in two different shops over the years. I felt intuitively that to be effective they must run at a high enough RPM where centrifugal force would serve to extend the flaps, I have a couple of air die grinders and have always been too afraid to use them with these wheels. Some wheels are marked for max RPM of 23,000. A couple of days ago, inspired by this thread, I finally looked into a variable speed electric die grinder and ordered the Vevor from Amazon.
            https://www.amazon.com/dp/B0DYV2P54S...fed_asin_title
            I'll let you know if the flappers survive
              I use flap sander wheels on a grinder to smooth out the castings on new cast iron cookware since the pre-seasoned stuff we are getting from the likes of Lodge are junk... Never tried them in drill format. probably easier to manage...
