What's this tool?
  • wood wrangler
    • Nov 2009
    • 22
    • Western Chicago burbs
    • bt3k, with the 3100 shim update
    What's this tool?
    I know it's generally a corner clamp, but I need to figure out specifically what it is. It's been in my garage for over a decade doing nothing, so I want to sell it. And that means having enough info on it to track down its value.
  • mpc
    • 1018
    • Cypress, CA, USA.
    • BT3000 orig 13amp model
    I think it might be missing a few pieces. Look at this craigslist image and the 3rd image in the same post:
    Possible version of this tool
    In the circular clip-like things the craigslist example has what look like guides for a saw, similar to the slot guides in a basic miter box. Set the distance between the two corner-clamp pieces to whatever distance your picture frame requires, flip one guide down to the workpiece, insert a saw, and cut one miter. Flip that guide up and out of the way, then repeat with the other guide. Now your workpiece has miters on both ends. Insert another workpiece and make a perfectly identical length second side for the frame. Then flip both guides out of the way and use this gizmo to clamp three frame pieces into two corners for glue-up.
    That's my best guess. The craigslist post doesn't list the manufacturer unfortunately.
    mpc
    • wood wrangler
      wood wrangler commented
      Interesting info—thanks!
      capncarl commented
      I believe someone somewhere is looking for this tool for parts. Maybe they have what this one is missing. Sell it, you didn’t even know you needed it!
    Almost certainly some kind of picture frame tool or jig... looks like able to make two corners at one setup.
    did a Google image search... got the Craigslist link mentioned by mpc.
    Click image for larger version  Name:	image.png Views:	0 Size:	1.35 MB ID:	859060Got a couple more important pieces, looks like cutting guides that flip down, but yours is cleaner with less rust.
    • wood wrangler
      • Nov 2009
      • 22
      I sent the seller of that tool a message so hopefully they'll have some more info to give me on it.
