Titebond speed glue for wood
    • 22085
    Titebond speed glue for woodClick image for larger version  Name:	01105_4714GP_Speed_Set_Eblast.png?width=1110&upscale=true&name=01105_4714GP_Speed_Set_Eblast.png Views:	0 Size:	259.0 KB ID:	839699
    But its only available in 1, 2.5 and 5 gallon sizes!
    I was thinking I could pick up a 4 oz bottle to try and use when I needed something that set (twice) as fast.
    And it doesn't even say, is it waterproof?
    • 8803
    I saw that today also. I would like to have some. There is a Titebond in an 8 oz bottle that is fast:
    https://www.lowes.com/pd/Titebond-Cl...l-oz/999992186
    I have some of that but I haven't tried it as a speed set.
    • Carlos
      • 1893
      • Phoenix, AZ, USA.
      Quick and thick is interesting, but it's not a replacement for normal glue. It's a bit too heavy.
        • 3790
        Thick vrs thin.... I’ve noted that thick superglue doesn’t hold as well in test conditions as thin. Probably because the thin soaks into the wood pores better than the thick.
          • 22085
          do you really mean superglues or do you mean wood glues like this thread discusses?
            • 3790
            Yes, I was talking about thick superglue, the same properties that make thin superglue hold tighter should also be true with this Titebond.
              • 8803
              OFF TOPIC FROM TITEBOND.
              Capncarl, it depends more on the situation /context than the specific CA glue type and I am sure this could be applied to Titebond also.
              Thin DOES sink into the wood better. That is a given. But Thin also thins out in small gap situations and does not maintain a lock between one board and the other all the way across except in perfect conditions. This has proven to be true in pen making. AS the pen blanks are drilled out and there is a small gap between the hole in the wood and the outside of the brass tube (when it is inserted in the hole), it has been proven time and again, that the thin CA glue is not making full contact fully between the two; if the mating is not perfect, the glue will not fill in fully and leave gaps. Many times Thin CA will drizzle all the way through and come out the other end.
              It is eye opening to see a "blowout" of a blank (caused by one of several possible reasons) and see the actual adhesion spots inside. The blown apart blank reveals where adhesion was and is. Thick CA and even epoxy do have more as they are gap filling (And this applies to Titebond also), but even those (in pen blank situations) do not adhere fully. The only fully adhering gap filling glue is polyurethaning glue that bubbles and expands.
              Bottom line is - in gap filling situations, thick will do better (be stronger for the situation) than thin in both super glue (CA) and Titebond.
              • Carlos
                • 1893
                • Phoenix, AZ, USA.
                Same with the Quick and Thick versus standard. Gluing up something that's not perfectly flat and smooth, the thicker glue is far better. But it behaves a little oddly on normal, fully finished, hardwood glue-ups. It could be I need more practice.
                For cyano, I can't say enough great things about the 2P-10 products and having ALL of them on hand for the specific task, along with nozzles and needles.
