Drill speeds and feed rates
  • Carlos
    • 1893
    • Phoenix, AZ, USA.
    It's very hard to find previous discussions on this using the search, but it seems like something that would have come up. I'm looking at a variety of speed charts all over the web, and they disagree with each other. Sometimes by 2x or more. I made a spreadsheet using Irwin's SFM formula and SFM charts, which comes up with wildly different numbers compared to several pre-calculated charts I could find. Do you have a chart you really like? Link?
    Any reason to disbelieve the Irwin formula and SFM recommendations here? http://www.irwin.com/uploads/documen...ents_Guide.pdf
    • 22085
    I just go with the widely circulated Wood magazine chart. Works well enough for me.
    May not be perfectly optimal but I think there's a lot of leeway.
    http://www.woodmagazine.com/content/...ss-speed-chart
    WOOD DrillPressSpeedChart.pdf
      • 3790
      It's so hard to change the speed on my drill press/milling machine that I usually use whatever it was left on the last use, and adjust my pressure accordingly. When I have to change it I use the speed recommended in my machinist manual.
        Good discussion. I tend to just go faster for smaller twist a bp bits and slower for forstners. I am sure I am often
        going faster than I should. It doesn't help that the digital readout on my DP has been broken for quite a while.
          • 8803
          Below is a photo originally posted by Loring quite some time ago. That speaks volumes on the correct speed, or at least being fast enough. Most of the time we try to keep from going too fast, but going fast enough is just as important.
Name:	Drill bit speed.jpg
          • Carlos
            • 1893
            • Phoenix, AZ, USA.
            It is clear from my research that almost all of us amateurs run the RPM too slow, and the feed pressure slightly fast. The ratio of feed rate to RPM is an interesting one, which I tried to reflect in the spreadsheet I made. This uses approximately middle ground numbers for the SFM and IPM ratios. Most of the speeds end up being slightly higher than the pre-made charts. And for the small sizes, my custom chart shows 3k RPM, because that's the max for my press. Most of those should actually be MUCH faster.
              • 22085
              Click image for larger version  Name:	Drill bit speed.jpg Views:	1 Size:	104.6 KB ID:	829541
              That's from when I only had a 5-speed DP, an improvement from the old 3-speed I originally got.
              Now I have 12 speeds. But I do change frequently. It's not that hard; it has three pulleys, two belts. Chart is in the cover. Takes less than a minute if I don't have crap piled on top of the DP.
              • tfischer
                • 2349
                I have a 16-speed DP but tend to use only 2 speeds... the second slowest (for forstner bits) and the second fastest (for twist bits). In the rare case that I drill metal I might put something in-between.
                (why second slowest/fastest? Habit... and I just happened to use those because it's an easy belt configuration to set up without looking at the chart)
