capncarl,
The only insulation offered by the manufacturer was 1/2" urethane under the floor, and I took that option. The floor itself, is LP Smart Flooring which has some insulating qualities according to the local dealer. Likewise, the siding and roof sheathing is all LP TechShield. In addition, I plan on installing a floating floor of some kind of laminate, with a foam backing. For the time spent out there, it should be adequate I hope. Actually, I'm back and forth about putting a moisture barrier down. From everything that I've found so far, it's important to keep the PT base well ventilated. I thought of putting down a moisture barrier under the gravel, but couldn't find any current information on whether that is a current policy. (I seem to recall years ago that placing a moisture barrier under a concrete floor was advisable, but I didn't find any current recommendation for doing so with a gravel bed.)
Regarding full-time heat, probably not this year. But if I go the expense of the permanent gas-fired wall heater then most likely that will be the case, just reducing the thermostat when I'm done working. When I first remodeled the old garage in Painted Post, making it my office, I used to just turn the unit off. That wrecked three hard drives on my computer, as it just couldn't handle the temperature changes. (It took me awhile to understand what was going on with my new Gateway at the time. Once I kept the heater going, albeit at a lower temperature, I never had another drive problem.)
radhak,
Understand about living in Florida and not requiring heat... but then depending on where in Florida you live, I don't have some of the other problems that the tropics can present.
JimD,
Well, that's what I first thought... the construction is mostly 2 x 4's, so I plan to insulate both walls and ceiling to R15. It's only 240 sq ft, so I thought something along the lines of a space heater would be just fine. I've had three people tell me that I need at least 30,000 BTU's. I think that's a bit much, but I do plan on finding out this winter with just a space heater of some kind. My room back at the PP house is 14 x 22 and it heats fine with a smaller wall heater, but that's an attached garage with only three walls exposed. That might make the difference, but that much I'm not sure of.
Thanks again to everyone, lots of good information from you all to digest,
radhak,
JimD,
twistsol
