Belt Sander Grit Survey
    • 22060
    WHat Grit do you keep as your "to go" sandpaper on you primary belt sander?
    47
    Coarser than 50
    0.00%
    0
    50-59
    0.00%
    0
    60-79
    10.64%
    5
    80-99
    38.30%
    18
    100-149
    38.30%
    18
    150-199
    12.77%
    6
    200-219
    0.00%
    0
    220
    0.00%
    0
    finer than 220
    0.00%
    0
    The poll is expired.
  • cork58
    • 365
    • Wasilla, AK, USA.
    I have a belt sander around here someplace but can't remember where it is.
    Cork,
      • 9554
      I believe my eb4424 came with 80 grit and I have just gone back with 80. Generally speaking, I use the belt sander for shaping, then smaller Sanders for removing scratches...
      • lrr
        • 380
        • Fort Collins, Colorado
        • Ryobi BT-3100
        You mean you can get medium and fine grit for a belt sander?
        • rcplaneguy
          • Nov 2012
          • 37
          Belt sanders are reserved for fast stock removal in my routine, so no need for medium/fine grits
            • 2811
            I have only two, the Ryobi bench top BD4600, which I believe is around 100 or 150 grit (it's still the same OEM belt from 2005).
            My old hand-held Craftsman 315-11720 (1971?) is a 3 x 21 and mostly has had 100 grit on it.
            I bought that thing when I was rather young and significantly inexperienced. Very aggresive, I've used it only rarely for cleaning up old, and very rough stock.
            • Stytooner
              Roll Tide RIP Lee
              • 4301
              • Robertsdale, AL, USA.
              I use worn 80 grit belts for finer work.
                120 normally but obviously that changes with the job. 60 - 80 for fast removal and up to 220 for rare smoothing work before the ROS gets used.
                  • 3784
                  I keep a 60 grit on my 6x48 machine and 80 grit on the 4x36 machine.
