Box joint bit ?
Another good source for small metal shims are the cheap feeler guages from HF.
http://www.harborfreight.com/cpi/cta...emnumber=32214
This HF automotive body shim assortment is pretty handy too:
http://www.harborfreightusa.com/usa/...o?itemid=93754Last edited by pelligrini; 03-23-2010, 10:40 AM.ErikComment
I like the idea of putting a dollar to good use.
So you'd need to get 35 shims from the dollar... which works out to ~2.9 cents each.
Does anyone know if Brian H. sells something similar to the stock spacers?
(edit: Found this, but no description. Waiting on call back from Brian. http://www.holbren.com/whiteside-shim-washer-kit.html)Last edited by Bill in Buena Park; 03-23-2010, 11:48 AM.Bill in Buena ParkComment
When, in the past, I need shim stock I just asked a friend who was a machinist. I expect a good machine shop would have it in various thicknesses and be able to just cut off a piece for you. Of course you may have to repair his dining room table to pay for it.
Another thought is Teflon, that too was available in thicknesses ranging from thinner than tissue paper to millable blocks. When the bit heats up the credit card stock may get soft and the cutters loosen up on the spindle. After some use the quality of the joint may deteriorate.
over here in the sunComment
yeah, i'm a little worried about the plastic long term, but it seems to be OK.When, in the past, I need shim stock I just asked a friend who was a machinist. I expect a good machine shop would have it in various thicknesses and be able to just cut off a piece for you. Of course you may have to repair his dining room table to pay for it.
I don't know any machinists offhand. I found rolls of brass shim stock in sizes from 1 mil up to 20 or more mils. But it was like $10 a roll plus shipping and i might have needed a couple of sizes. Didn't want to spend $25 shimming up a $25 bit... haha.
You'll never make it in government with that attitude
You could just lap brass washers until they are the right thickness, could be a bit time consuming though.
An auto parts store that does machining may have the stock too.
Ever notice that when you factor time into a buying decision you pay yourself full rate?Comment
its not that i couldn't find any, its that i couldn't find any that wouldn't have cost $15-20. That's about what Lowes wanted for a 6x24" sheet of that stuff.
I don't know if the case anymore, but I used to get small sheets of aluminium, steel & brass as well as strips, tubes and rods at some hobby stores back when I was making architectural models. Michaels used to carry some, but a mom and pop shop carried quite a bit.ErikComment
Phil,
I didn't mean to ignore the question - i had to wait to get home to verify my memory.
The threaded arbor measures 5/16", it's SAE, I'm pretty sure by looking.
The large, thick spacers are 0.625" OD, exactly 5/8"
The thin supplied shims are .01" and .02" thick are 8mm ID x 13mm OD, seemingly metricish. Inch measurements are .315" and .520" respectively.
I made the cut in one pass. Had to go a little slow, but it was a hair over 3/8".
Yeah, I figured that after posting the second time. Duh. Sorry.Phil,
I was going to order one of those bits if I could find off-the-shelf shims that weren't too expensive. McMaster has some that are close but no cigar (all the numbers match but the I.D., which is 3/8").
Those joints are amazing, I think they'd be great for storage trays, etc.
I guess I'll wait for a follow-up and see how the credit card shims are holding up. If they continue to work for you I'll give it shot.
Thanks for the help.Comment
LCHIEN
