I recently picked up a Delta Unisaw for $500 on Craig's list. The iron top needed cleaning up, and the extension top was in rough condition. The fence and rails were scratched up and rough-running. I cleaned up the iron top with a die grinder and 3M pads, did a great job in only half an hour. Replaced the extension top with a nice pre-made setup from my local dealer. I took the fence and rails apart and sanded everything smooth (80/120/180/220/320), then repainted them. I drilled and tapped the Biesemeyer fence to accept HDPE screws from a SawStop fence, which improves sliding friction as well as allowing adjustment of the fence so it's perpendicular to the table. Finally I added UHMW strips in all the key places, and now the fence is a slick one-handed slider.
Mechanically the saw was great, so the only other work I did was to check alignment. I found the tilt stops were off by 0.1 degree and fixed them. The front to back blade alignment is off by .002" which seems quite acceptable. Should I even bother with that at all? A couple squirts of tool bed spray on the tilt/lift gears got them running so smooth that you can spin the wheel and let go, it keeps spinning. I also added the overhead guard arm that I picked up at a great deal. It really adds a lot of convenience, though I still find myself reaching for the switch under the saw many times. I also added a Wixey digital fence guage which I'd had around for a while without installing it.
I knew there must be a reason everybody thinks this saw is the best, but I was completely unprepared for the vast difference between my BT3100 and this one. I should have done it years ago. I'm simply stunned at the precision, power, and smoothness. It adds up to a better-looking end product and much less frustration. It's an absolute joy to use. I ran some MDF sheets through it today. The cut was perfect, plus I was able to make four strips that were within .003" of each other. The precision was aided by the Wixey digital fence guage, but made possible by the Biesemeyer fence. I was alone so I ran the half sheets in and pulled them back out (no outfeed yet); the cut was perfect and there was no issue with backing out.
So now the question of infeed/outfeed. I'm leaning towards the HTC folding roller table as outfeed. Any comments on that? Anyone use it? The saw sits right at the edge of the garage where the door closes right behind it. This makes my driveway "free" outfeed space, but I need to remove/fold any outfeed that I add.
I need to build myself a decent workbench, so I was thinking about making it the right height to work as an infeed solution. Thoughts on that? I don't really have the space to leave something set up as infeed all the time, and really, I rarely find myself needing it.
LCHIEN
