Which Multi-Tester?
  • silverfox
    • 2863
    • Richland Center WI, USA.
    Which Multi-Tester?
    HF has their 7 function Multi-Testers on sale again....
    http://www.harborfreight.com/cpi/cta...emnumber=30756
    http://www.harborfreight.com/cpi/cta...emnumber=90899
    I know many members here have one of these and I wonder if someone could tell me which is the best one to buy? It appears that the cheaper one has a continuity response and no battery tester and the more expensive one has a battery tester and no continuity response tester. Although, the copy in these ads is not always accurate. There are other differences as well, I guess....like an auto zero adjust and over range indicator. Since they are both cheap...money is not an issue. I want/need one of these but don't know much about them....which one is the best to own? Thanks.
  • Stan
    • 966
    • Kalispell, MT, USA.
    • BT3100, Delta 36-717
    At those prices, I'd get one of each. Never hurts to have a spare.
    http://www.elksigndesigns.com
    • frumper64
      • 376
      • Garland, Tx, USA.
      I've got a couple of the 30756 testers (one in the garage and one in the toolbox of my truck). They have worked just fine for me. This is one of those items that HF puts on sale every couple of months. As far as battery tests, it has several DC volt ranges, and for continuity it has several OHM ranges, so both should be covered.
      64sedan_at_gmail.com
      • rbfunk
        • 400
        • Garfield, NJ, USA.
        Mike,
        As an old electronics geek, I would have said pass on them because they are so cheap but since Jim has bounced one around in his truck I'll go with Stan and say get 2.
        Also Jim has a point. The voltage ranges will test batteries and you can use the 0 -200 ohm range for continunity
        Don't forget the leads
        Bob
        Oh what a tangled web we weave, when we are all hopped up on caffine.
        • Tundra_Man
          • 1589
          • Sioux Falls, SD, USA.
          I've also got the 30756 tester. I've compared readings with the Fluke we have at work and they're pretty consistent, although the Fluke seems to finalize a lot quicker than the HF.
          But for $2.99, you can't complain. It's a lot better than my old Radio Shack analog tester which I paid through the nose for 15 years ago.
          Terry
            If the continuity tester has a beeper then its much handier than a regular ohm function because you can test without looking at the meter.
            Not familiar with those particular units.
            • WayneJ
              • 785
              FWIW
              I had a big buck fluke at work and a radio shack one at home. When I retired I made the mistake of leaving them in the unheated shop over the winter. The LCD screen in both meters lost most of the display. Don't know why but they are both junk now.
              Wayne
              Wayne J
              • silverfox
                • 2863
                Hey Bob...the ads say that they come with 32" leads...do I need more? Yeah...nice to know that it holds up in your mobile tool box, Jim.
                And thanks to everyone that has responded to date. I have been using a light, no light tester in the electrical functions of this old house but I really need a volt meter and a tester for other functions. I heard that these were just as good as any for a non pro like me. Might be a good idea to get two as suggested for the low prices. HF also has this one...
                http://www.harborfreight.com/cpi/cta...emnumber=35761
                But except for the back light in this one and an on/off switch on one of the others above...they pretty much all look the same to me. Might be nice to have that back light...I've been in situations where it would have come in handy. Sure are cheap for all they do. I've seen these things in the 30 to 60 dollar range. But I've heard people here say that these are good bargains...at least for someone like me that won't be using it everyday. If anyone here has had problems with these let me know...but I think I will probably get one or the other of them.
                • RagerXS
                  • 501
                  • Brookline, NH, USA.
                  If I didn't have a nice fluke I would get one of these. In fact, the price is so low that I may consider picking up the one with the back light at some point anyway. I can't tell you how many times I've held a flashlight between my shoulder and neck and tried to check voltage to ensure the circuit I want to work on is actually deenergized along with the lights in the room. My current home has lights on separate circuits, but you never know when the back light will come in handy somewhere else...
                  Get one cheap one and one with a back light.
                  ~ Fred
                  • rbfunk
                    • 400
                    do'uh!!!
                    Thats what I get for posting quickly from work. I saw that they had leads as an accessory and figured for those proces they can't include leads.
                    If Terry's matches his Fluke, then I predict that you will be happy with them.
                    Bob ( who used to work for John Fluke Mfr. )
                    • Stick
                      • 872
                      • Grand Rapids, MB, Canada.
                      I use Flukes at work and the same type of little meter you guys are talking about at home. You seldom really need the accuracy of a Fluke. Besides I have an old Simpson analog meter that I use much more than any of the digitals. Backliting would be a nice feature.
                      • HarmsWay
                        • 878
                        • Victoria, BC
                        Agreed, very useful feature.
                        Bob
                        • silverfox
                          • 2863
                          I rather doubt that the $2.99 HF model has a beeper.......
                          • BobSch
                            • 4385
                            I bought 2 of the $2.99 specials for a theater I work with. I CAN tell you they won't survive a 30' drop onto a concrete pad, otherwise they're just fine (well the surviving one, anyway.)
                            Bob
                            • silverfox
                              • 2863
                              Well....SHOOT!, Bob. I guess I'll have to pass on one of these. My first use for it was going to be to drop it 30 feet onto a concrete pad. Oh well.....
