Which Multi-Tester?
  • mmcduffie
    • 146
    • Des Moines, Washington.
    Wanye,
    About your displays not working on your DVMs, they use a conductive elastomeric strip to get the signal from the PCB to the LCD. See if you can take your meter apart far enough to pull the display from it. Pull slow and steady, the strip is probably stuck and you don't want to tear it. By taking it apart and putting it back together you will make good contact again and the display will work. Do be careful with the display, as it is very thin glass. I've fixed several displays this way, including the one in my 15+ year old Fluke 87.
    HTH
    Michael
