Do You Own a Dado Blade?
  • dkerfoot
    • 1094
    • Holland, Michigan
    Just curious how many people own dado blades and if so, do they get used?
    338
    No
    16.86%
    57
    Yes - I use it and would replace it if lost or stolen
    57.99%
    196
    Yes - but I rarely if ever use it
    25.15%
    85
    Doug Kerfoot
    KeyLlama.com
  • smorris
    • Apr 2003
    • 695
    • Tampa, Florida, USA.
    I seldom use mine because for the most part it is easier to setup the router to make dados, not always but usually.
      for short, stopped dados I use the router, but for long, deep and CLEAN dadoes I much prefer the saw/dado blade combo.
      • Thalermade
        • 791
        • Ohio
        • BT 3000
        I guess I actually own two, the Freud 6 inch dado set and the Freud Box Joint set.
        Like Loring, it depends on the cut whether I use the router or table saw.
        Russ
          I've got a couple sets and one of them wouldn't be missed. I got a wobble blade many years ago for my old Skill bench TS. The arbor wasn't long enough and I don't think it's ever been used.
          A box of saw blades ended up in my garage a couple years ago and there was a old Craftsman stacking set in there. I use it often, but I would still like to get a really good stacking set that will make a true flat cut.
            I have a few sets of stack blades and a couple of wobble blades (that I don't use). For dadoes, I prefer to use a router. For large or long runs holding down the sheet on a TS is a chore. Cutting face down and sight unseen, are two concerns in using the TS, IMO.
            • Schleeper
              • Feb 2008
              • 299
              Freud 6" Super Dado. Purchased only a couple weeks ago for use in building some cabinets, but haven't used it yet.
              "I know it when I see it." (Justice Potter Stewart)
              • Knottscott
                • 3815
                • Rochester, NY.
                • 2008 Shop Fox W1677
                I tend to use the dado over my router, but have used both. The dado set has more flexibility and cuts faster. I also prefer the cast iron table surface (and size) over my router table surface. If I use the router it's typically for handuse, not the router table.
                • vanguard
                  • Jul 2005
                  • 287
                  • Brighton, MI, USA.
                  • Ridgid TS2400SL
                  Avenger 6".
                  • MikeMcCoy
                    • Nov 2004
                    • 790
                    • Moncks Corner, SC, USA.
                    • Delta Contractor Saw
                    Ditto - I have a 10" Canadian set but have no idea what the brand is that I purchased from a cabinet makers supply shop.
                      Forrest 6" Dado King. Used once. Primarily use the router table because setup is faster.
                      • rnelson0
                        • Feb 2008
                        • 424
                        • Midlothian, VA (Richmond)
                        • Firestorm FS2500TS
                        Funny you ask this. I bought an 8" Freud stacked set about a month ago cause it was on sale and I plan on building some cabinet-type projects (pantry, bookshelves, etc.). I was feeling bad about not using it so I decided to go build a cabinet from leftover scrap yesterday - it's a cabinet I'll never use, because of the size of the scrap, but I learned a lot from it anyway.
                        If I build a router table, I'm sure I'll use that as well, but my router table is much bigger and would require less infeed/outfeed support. If the project was really large, over 72", I'd probably have to use the router on an edge guide because then I lose the fence on my tablesaw.
                        Otherwise, I like the dado - awesome clean cuts and hey, I paid nearly $100 for it! It is somewhat scary though that sometimes your face is basically right over it, so if you do find a piece of metal in your wood, you're going to have a big surprise to deal with. I'm okay with having a hand on each side of the blade, it's my head I'm worried about.
                        • DUD
                          • 3309
                          • Jonesboro, Arkansas, USA.
                          I have the Frued 6 inch Dado set and use it frequently. I would definately have to
                          replace it. I use a router sometime, but usually say up the saw. Bill
                          • sparkeyjames
                            • 1087
                            • Redford MI.
                            No, but I want to be a dado blade owner. Really I just don't have the use for it right now and I probably will not for the short range future either.
                            • WayneJ
                              • 785
                              If its a long rabbit or dado I will use my 8" freud set . For a short run I do it on the router table.
                              Wayne
                              Wayne J
