How high is your router table?
    Well, I finally got around to it. Mine is just shy of 36 7/8". I'm 5' 8" tall.
      I am 5' 11" and I made mine 39" high. It is just right for me.
        Just measured mine. It is 38 3/4"
        • plarval
          • Apr 2004
          • 212
          • Akron, Ohio, USA.
          #34
          I don't let it smoke that stuff anymore. Everything came out crooked!
          • Schleeper
            • Feb 2008
            • 299
            #35
            In the neighborhood of 37" (the height of my BT3000 table.)
            "I know it when I see it." (Justice Potter Stewart)
            • smorris
              • Apr 2003
              • 695
              • Tampa, Florida, USA.
              #36
              The one I'm working on now is going to be about 1/8" lower (about 38") than the top of my BT3100 so it can do double duty as an outfeed table. I've used the table on the saw for a couple years now but have been finding it crowded at times so I'm making a stand alone table.
                Decided to build a dedicated router table, and it's going to end up at about 39 in. - I'm 6ft, and that should be just about right. I've used my 21829 accessory table a bunch, and (with a new fence I made from some leftover 3/4in melamine) it has done a great job - but can't handle my raised panel bits.
                Going to use some left over 3/4 melamine for the top (thinking 32 x 24), using a Jessem phenolic router plate (http://www.woodcraft.com/family.aspx?FamilyID=5030) that has the 3-1/2 opening I need for raised panel bits. The router housing box under it will be about 12" high, and I'm putting it on a HF universal tool stand (http://www.harborfreight.com/cpi/cta...emnumber=46075).
                I like these tools stands for this price - put a bunch of my other benchtop stuff on a few (DP & BS, OSS & 12"DS, RAS, TP, etc.) The nice thing is, the legs have a small bottom piece that allows for height adjustment; I'll start at the shortest setting (26in) which gives me my 39" total height; if that feels low, I can go up to 42" or 45".
                • dkerfoot
                  • 1094
                  • Holland, Michigan
                  Mine is 35 3/4 - the same as most other surfaces in my shop since my 21829 is 36". I can and do use everything else as an infeed/outfeed/support surface.
                  My workbench is 34" in part because I do like that a bit lower and in part because I built it before I bought the saw. It still works as a support surface with strategically placed 2 by cutoffs.
                  My shop is only about 10' x 11', so I need to make use of every surface I can - though many boards end up going out the door...
                  Doug Kerfoot
                  KeyLlama.com
                    Gotta love new users digging up old polls.
                    Welcome, whoever you are.
                      • 3128
                      #40
                      I didn't even look at the date and dutifully went out and measured.
                      Anyway, mine is 36.75" and I'm 6'0" tall. I think it is easier to see if it is a little lower, my old one was at 40.75 which I only know because I made the new one 4" shorter.
                      • Carlos
                        • 1893
                        • Phoenix, AZ, USA.
                        #41
                        Well, it sent me an update notification and reminded me that I haven't poked my head in here in a very long time. So much for my productivity this morning.
                        Oh yeah, my router top is at 40" and after a couple years of use I find that to be perfect for nearly everything. Working with very large items is the only small exception; it could be lower for that. But I rarely do it.
                          • 2813
                          Same height as my BT31001.
                            Mine's way too high. I'm going to be up all night trying to talk it down.
