Please rate this thread with 3 stars, then comment.
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Did you rate this thread with 3 stars?
    Were you able to rate this thread, or did it say that you had already rated it?
  • BigguyZ
    • Jul 2006
    • 1818
    • Minneapolis, MN
    My vote was added successfully....
    • sweensdv
      • 2872
      • WI
      • Baileigh TS-1040P-50
      Couldn't do it, as you suspected, it said that I had already rated this thread. So, I rate this thread 4 stars for not letting me rate this thread. Why would anyone want to rate a thread in the first place? Where do ratings go, if anywhere?
        It said I have already rated it.
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          Yay! I'm not losing my mind after all!
          Is there a moderator out there who has taken note of this bug?
          sweensdv -- I see the ratings on the front page next to the thread title. But if they're not commonly used, they can be misleading. For example, 1 star (which is a "Terrible" rating) looks better than no stars at all (which is most common).
          MODS - I don't know if it's configurable, but you might consider changing the ratings to "Good", "Better", "Excellent", "Superb!" and "Will turn your life around" -- or something along those lines...
          • phi1l
            • Oct 2009
            • 681
            • Madison, WI
            well.... I don't know that we can say that quite yet
              How would you rate that?
              • herb fellows
                • New York City
                [QUOTE=Alex Franke;458395]Yay! I'm not losing my mind after all!
                This is not a guarantee that you are not losing your mind; it merely says that in this instance, you have confirmed what you thought you saw.
                Take it from someone with mind losing experience!
                Oh, yeah, it said I had already done it also.
                • steve-norrell
                  • 1001
                  • The Great Land - Alaska
                  It says that I have already rated the thread. But I did not. SN
                  • phi1l
                    • Oct 2009
                    • 681
                    • Madison, WI
                    OK, .. I just rated the Small bit set thread 4*. CAn someone else now ad a rate to that thread??
                      Can't rate it.
                      I doubt Sam will mess with the bug at this point. We don't use the thread rating feature that much. We should eventually be going to VB4 in the near future too.
                      In the admincp on a VB install of mine there are options for allowing a user to change his rating and when to display the ratings in the forumdisplay.php and showthread.php. The default is for 2 rating votes needed for a rating to show up.
                      The "Update Thread Last Post on Poll Vote" switch would be a good one to change from what we have now. A person voting in a poll wouldn't show the thread as it had new posts. Might mean less participation in polls though.
                        • 9542
                        I cannot rate this thread. It says I already did...
                        • rcp612
                          • 358
                          • Mount Vernon, OH, USA.
                          • Bosch 4100-09
                          I subconsciously rated this thread before I opened it.
                          Oh well, mind over matter,,,,,,,,not that it matters,,,,,,,
                            I am always logged in as an Admin and I also get the "already rated thread" I'll pass this along to the Chief bottlewasher for fixing...
                            • charliex
                              • 632
                              • Spring Valley, MN, USA.
                              • Sears equivelent BT3100-1
                              It says I already rated this thread. I plead not guilty as I did not rate it now or in the past. I didn't even know I had the ability to do so. Honest I'm innocent. It could have been my evil twin.
