Going to give Chainsaw mill a try!
    • 8773
    My daughter in southern Missouri has 6 Ash trees in her yard, 4 of which are either completely dead or 80% dead of foliage, thanks to the emerald ash borer. Two trees have enough foliage that warrants treating and saving, which my daughter has done (three weeks ago). I helped her (OK, I did it) cut down one tree that had a huge limb over her roof at that time. That tree never did sprout leaves this past spring and it is dry. 24" around.
    I am going back to Missouri over Labor Day weekend and cut down two more trees and trim a third one. The one tree I cut down showed no sap in it. I decided to give a chainsaw mill a try for the one cut down and for the other two that I have to cut down. All are between 18 and 24" in diameter and have boles (trunks) about 8 ft of clear trunks. I sure wish I had a mobile bandsaw mill, but I don't. I probably will cut it into 4 inch thick slabs 12 inches wide and try re-saw on my bandsaw back here. I probably will not be able to bring more than two 18" trunks at a time or one 24" in my light weight (1500lb capacity) trailer.
    I have a 24" chain saw and will probably be able to cut 18" width at the most.
    Sure could use some nice ash wood. I will report back.
    Any advice?
    • 22003
    Do you have to treat the wood to rid it of insects that can spread to other trees? A lot of times the wood has to be treated or destroyed if the tree is killed by specific pests to keep the cycle from repeating.
      • 8773
      The arborist said that the fully dead tree did not have any. They do not bore into the wood, but live underneath the bark only - and only as long as the tree is alive. They are now in 35 north eastern, eastern, midwestern and southern states and several provinces in Canada.
      I don't plan on bringing any live edges back anyway, so all lumber will be milled lumber. Nothing like we find on 2x4s in HD.
      OH, I forgot to mention that I have malathion spray and plan on covering the wood with the spray.
      • Slik Geek
        • Dec 2006
        • 708
        • Lake County, Illinois
        • Ryobi BT-3000
        I love ash trees and ash wood. We lost five trees to the borer a couple years ago.
          Hank - don't forget to leave some of this for turning blanks! Sounds like there's so good bowl potential in there.
            • 3752
            My oldest has an Alaskan bandsaw mill. I don’t know the difference, and don’t know what size bar his saw has but I think it is larger than 24”.
            He has cut quite a bit of several Sweetgum trees from his yard and successfully made usable planks . If it will handle Sweetgum which is a stringy tough grain wood, ash should be a breeze. I believe he spent quite some time building different frames and guides, it wasn’t just a buy it and use it tool. He tried to get me to buy one but I didn’t want to get into another hobby and don’t want to have to find a place for more tools!
              • 8773
              https://www.yahoo.com/news/invasive-...123054005.html
                atgcpaul commented
                I discovered that I have something like that going on in my backyard. My deck seems to be a magnet for carpenter bees. I also noticed these giant horseflies (yes, even bigger than horseflies) flying around. I snapped a picture of one, ran it through Google lense, and found out it's a Tiger Bee fly. The females lay their eggs in/near the carpenter bee bore hole and the larva go eat the carpenter bee larva.
                They must be in pretty good balance or there aren't enough Tiger Bee flies because the carpenter bee population around my deck doesn't seem to be dwindling.
                capncarl commented
                I’m Leary of any invasive species. Their intent always seem to backfire, and they cause other problems. I’d hate to find out that these Tiger Bee Fly eventually attack our honey bees and other pollinators. The pollinators in my are just about non existent in my garden and we are seriously worried about them. All of the nearby farmers use aerial crop duster planes quite regularly, I expect that’s the problem, I’d hate to have another problem.
            • anglinastone
              • Sep 2022
              • 7
              • United States
              yeah, a portable sawmill can be worth the investment. It can provide a source of wood for your own projects and give you a side business. For a source of lumber, as well as a profitable business, a portable sawmill can be a key piece of equipment on your farm.​
                • 22003
                If you have carpenter bees, I have made a number of traps that work quite well.
                https://www.sawdustzone.org/forum/di...carpenter-bees
                I have made a simpler version, just takes about a 5- or 6 inch piece of 2x4. I'll post it maybe a new thread tomorrow.
                  • 8773
                  No Kidding! I can do that? Who would have thought it? And silly me was just buying it for an investment like precious metals - since I no longer live on a farm.
