Creating a groove for a charging cord
  • tfischer
    • 2349
    I have both an iPhone and an Apple Watch, and would like to get an organizer on my nightstand which will give me a place to charge them without so much clutter. Seems like a fun little project to build.
    In surfing the net, I see a few designs made of wood such as the following:
    I like the simplicity of this one, but my first question is "ow in the world can I make that little cable grove going from the watch charger holder (the circle at left) to the other side? I'm assuming I could do the other slot and notch (for the iphone) on the router table, but the thin little cord slot curves and such.
    Thoughts?
    I recently needed to cut a groove like this in a project. I have a dremel with a router base, and used the small straight bit to do it. It was likely 1/8 wide, which was ok for my application, but not sure if that works for your cord. Anyway, I'd make that the first operation on the raw block, and use a template and bushing to guide it. Likely need several passes with the bit lowered each time until you reach the desired depth. Then make the other cuts.
      • 8774
      That picture makes it look like there are three or more boards laminated together. It looks like the cuts were made and then laminated together and then sanded to look like a it was cut as a single piece. Otherwise, it was done with a laser or computer controlled router of some sort.
      I am curious as to how you make one. Let us know.
      • Stytooner
        Roll Tide RIP Lee
        • 4301
        • Robertsdale, AL, USA.
        I would say like Hank. Some machining was done before glue up and some afterward. Pretty cool item.
          • 22012
          My first thought was that the circle, the wire groove and the cellphone slot are all manageable with a set of three templates (or one if you prefer). THe thin slot is hardest becausehigh aspect (depth to width) bits are very easily broken if taking too much depth of cut, so it will take a lot of passes and I'd buy an extra bit or two as inusrance that you don't need it. The thing that's not clear is the depth of that thin slot - just at the end or over the whole length to the watch cup?
          Using a template guide bushing with your template(s) would be the way to go.
            • 3756
            Plan it like you were building a band saw box?
            capncarl
              A friend recently made a "Bedside Butler" from zebra wood with a similar groove for the iphone cord. Most was done with a router and template but the section for the cord and plug end was done with chisels. His was a little flatter in shape though.
              • tfischer
                • 2349
                I can't even picture how I'd do that narrow cut as a glue-up.
                  My take on Hank's lamination thoughts:
                  Not knowing dimensions of this - If you took 9 square pen-blank sized pieces, to be glued up 3 high and 3 deep - before glue up, take the top center piece and cut in the slot with a band saw; then, glue up and do the other machining. If this is only a 3-layer glue up, you might take the top layer and cut that slot in with a scroll saw - then glue up and do the other machining.
                    • 3756
                    Build it like it was a band saw box..... Top layer of wood ONLY has the slot that can be cut with a band saw and since this piece can be cut in half, can be finished with the router or whatever. Then the top layer is glued back together since you cut it in half to get the blade in to the slot. Then you can laminate top layer to layer #2, maybe even layer #3 and cut your other holes. No aligning problems that way.
                    capncarl
                    • tfischer
                      • 2349
                      Some great ideas here. I need to get to my drawing board and sketch up something.
