Moving my step-daughter to Dallas slowed progress on my Ultimate Tool Stand build, but I was able to get some serious time in on it this weekend.
I finished cutting the hole pattern in the three top sections and it was time to permanently attach two of them to either side and make the removeable section, so that was my focus this weekend.
To attach the right and left sections I decided to use 5 blocks per side in this pattern:
I figured the center block would help support the panel. Each block is fixed to the section below with four pocket hole's and screws. It made for a solid base.
Next step was to make sure the holes aligned in the two sections. After all why go to the trouble to havea perforated top and not have the holes aligned with each other.
The bench dogs used have a flat side on them. I purchased them on Ebay (link). They are also threaded with 5/16" threads.
Then it was on to the center section which is removable.
It was put on a pseudo i-beam, with a dado cut in the top piece and narrower bottom pieces (visible in second photo) and is held down with a star knob and a threaded t-nut. But the holes still need to be aligned...
Some comments...
The holes align accross the top, however they do not keep the spacing from panel to panel. I didn't believe this to have long term importance in the use. If I needed to use the hole pattern to do angles, it was probably going to be concentrated on a single section and not across sections. It will work to have them be 90 degrees to each other from panel to panel if necessary, which I did feel could be useful in the future.
If I had to do over, when I had the template made to cut the holes I would have had it done with a 4 x 3 hole pattern, to make the moving of the template less frequent.
Next step....
The setup for the CMS. I have the CMS mounted on two MDF runners to align the bed with the top sections, however, I still have to assemble the fence. I will post pictures of that as I get to it. Have to put a coat or two of poly on the MDF fence sections and make a dado for the T-track part of the fence (the dado coming first of course).
After that I will work on the router table part. I have purchased the triton plunge router, but I still need to purchase or make a plate insert and craft the top.
Baby steps.
Some comments...
Next step....
Baby steps.
