it is frequently stated that a good glue joint is stronger than wood, a statement I've taken as the truth.
So if you pull it together with clamps and glue then the wood fibers will have to separate (basically the wood splits) before the glue joint comes apart. This of course depends on the joint being fully wetted both sides and no gaps etc all the requirements of a good joint and sound pieces of wood with no cracks.
LCHIEN
