My BT3000, What elce would I ever want!
If I had all the money in the coffers that I ever need, what saw would I buy I think that I would forgo a new table saw, and have it checked out, and any modification done that would make it safe, and work better, (if that's possible) would be to rebuild it, where necessary! I do not use Mine every day, so I don't know what needs rebuilding, and I certainly don't feel any thing that has changed in any way since I bought it. I would go and get a new band saw! One that can be used to cut boards off a tree slab, or side. I can see some real advantages to be able to cutting new boards from a larger slab of wood. I would also do something about my shop! I have a large basement shop. the layout is 28 X35 ft. with two walls separating it. Not an ideal solution, I would probably like to relocate so that My shop was separated, and not attached.
But to be honest, At My age, and My disabilities, it would not happen. It is a beautiful thing to think about, however!
If I had all the money in the coffers that I ever need, what saw would I buy I think that I would forgo a new table saw, and have it checked out, and any modification done that would make it safe, and work better, (if that's possible) would be to rebuild it, where necessary! I do not use Mine every day, so I don't know what needs rebuilding, and I certainly don't feel any thing that has changed in any way since I bought it. I would go and get a new band saw! One that can be used to cut boards off a tree slab, or side. I can see some real advantages to be able to cutting new boards from a larger slab of wood. I would also do something about my shop! I have a large basement shop. the layout is 28 X35 ft. with two walls separating it. Not an ideal solution, I would probably like to relocate so that My shop was separated, and not attached. But to be honest, At My age, and My disabilities, it would not happen. It is a beautiful thing to think about, however!
