Cutting Asphalt
  • gsmittle
    • 2793
    • St. Louis, MO, USA.
    Cutting Asphalt
    I need to cut a rectangular hole for a drain in my driveway. It’s about four inches thick. I don’t know the size of the hole I need because I haven’t bought the drain yet. What suggestions does the Brain Trust here have for cutting the hole.
    More details: No cars park where the drain hole will be. There is compacted gravel under the asphalt, and drains under that.
    Many thanks!
    Smit
    "Be excellent to each other."
    Bill & Ted
  • Black walnut
    • Aug 2015
    • 5514
    Rented concrete saw.
      • 3790
      What happens when you get the hole cut? What does the drain connect to?
      It’s hard to cut a square or rectangular hole in paving. As Black Walnut said, rental concrete saw, 4” of packed asphalt is hard to dig out. .
