Photo Lamp Project
    Photo Lamp Project
    Well, this is not technically a woodworking project but I dove into it the same way.
    THis was sort of my inspiration:
    Click image for larger version  Name:	image.png Views:	0 Size:	268.9 KB ID:	863754
    I have a 1950's tripod that belonged to my father that I used a lot as a kid to learn photography. I have a 2014 model Mirrorless camera that has failed and is beyond economical repair. And a bunch of slides from the 70s my late parents cruise vacations in the Pacific. People I don't know and locations I barely know. But I know it was their happy days, post retirement, kids gone or married.
    The camera failed a few years back, but I still use all the lenses on my other cameras. So I appealed on the camera enthusiasts forum to see if anyone had a broken, non repairable lens to volunteer. I bought one from ebay for $10 and someone eventually sent me another.
    I'm very familiar with cameras, they use a 1/4-20 stud on the tripod to mount the camera tripod socket. I was able to find a hotshoe to tripod adapter to put a 1/4-20 tripod mount on the top of the camera.
    Lamps there are all kinds of lamp hardware and I found out they have all weird threads. The riser pipes are all hollow and they are 1/8" IPS straight hollow pipe thread with 27 TPI pitch and the top finial for the lampshade is 1/4-27, another odd thread. Turns out the Lamp industry happened before ASME, SAE and all other standards. Before the Turn of the century they started replacing gas lamps with electric, but they tended to used the old piping to run the cord and other existing hardware to mount the electrics and that's how the odd threads came about as lamp standards. So you have to deal with a shop that handles lamp parts. I used Grandbrass.com.
    So the key part was a 1/4-20 to 1/8 IPS bushing to make the transition, after that I used standard lamp hardware.
    I selected the slides and searched for a variety of scenes. Some have my parents in them, a nostalgic touch that makes this personal. There are a few pictures of the giant stone statues on Easter Island - Rapa Nui.
    Other examples of slide lampshades the artists all drilled holes in four corners then used jewelry jump rings to connect. That was to me a massive labor effort and kind of floppy. I simply laid out a array or 19 W x 4 high and used straight edges to corral them snugly against each other. and then Taped the seams vertically then horizontally. from the inside of the cylinder. Such an arrangement can curve one direction and not the other. And when curved into a circle, the vertical joints become rigid.
    I actually did 6W x4 twice and 7W x 4 once to make it more managable then joined the three sections together to make my 19x4 cylinder.
    Click image for larger version  Name:	1000015869.jpg Views:	0 Size:	131.7 KB ID:	863762
    As expected the cylinder curved in one dimension and was rigid in the other with a whole lot less work than the jump ring method.
    Click image for larger version  Name:	1000015873.jpg Views:	0 Size:	166.6 KB ID:	863761
    I assembled the lamp. I had a few disassemblies because I forgot to thread all the stuff onto the power cord in the right order.
    Click image for larger version  Name:	1000015868.jpg Views:	0 Size:	118.0 KB ID:	863763
    The shade fit a 12" ring perfectly, which was partly luck because the slides are exactly 2" x 2 "; the slide cylinder circumference and the ring circumference were nearly perfect match so the ring sat just inside the slides. I had drilled the top and bottom row of the slides with a 1/8" hole centered on the edge and used 38 tiny zip ties to fasten them.
    Click image for larger version  Name:	20261013_114858.jpg Views:	0 Size:	158.3 KB ID:	863765
    It turned out that the clear/bright areas of the slide allowed you to see the bulb and hardware inside, so I had to order some diffuser material and line the inside which helped enormously.
    Click image for larger version  Name:	20261013_215140.jpg Views:	0 Size:	109.8 KB ID:	863760
    When I was done with the shade, I found I misjudged where everything would land an particularly that LED bulbs don't put much light downwards (whereas incandescents were glass and emitted ligth all the way to the base). So I had to get finial risers to raise the shade 2.5 inches.
    All sorted out, I installed it on the vintage tripod.
    Click image for larger version  Name:	20261013_214945.jpg Views:	0 Size:	60.9 KB ID:	863755 Click image for larger version  Name:	20261013_215234.jpg Views:	0 Size:	83.4 KB ID:	863756 Click image for larger version  Name:	20261013_214930.jpg Views:	0 Size:	91.1 KB ID:	863758 Click image for larger version  Name:	20261013_220500.jpg Views:	0 Size:	104.2 KB ID:	863759 Click image for larger version  Name:	20261013_215140.jpg Views:	0 Size:	109.8 KB ID:	863764
    Click image for larger version  Name:	20261013_215100.jpg Views:	3 Size:	76.1 KB ID:	863757
    I'm really happy how it turned out, looks cool and it has a lot of sentimental meaning for me, every single part - the tripod, the camera, and the slides.
    Click image for larger version  Name:	20261013_221032.jpg Views:	0 Size:	58.1 KB ID:	863766
    This knob, they don't do stuff like that anymore. I have fond memories of this knob from my childhood. It's a Davidson Star D "Conquest" tripod.
  • RobertBrown9
    Handtools only
    • Oct 2026
    • 1
    That turned out great! I love how you reused the old camera parts and your father’s tripod to create something so personal. The slides make it unique, and the sentimental value behind every piece makes it even more special.
      LCHIEN commented
      Thank you.
    • 3791
    I really like your use of slides, bringing them out of a box hid in the top of a closet to somewhere they can be seen! The idea of making a lamp shade out of slides could be elaborated on by taking photographs and turning them into photo size slides (I can’t remember the photo talk name) and create room lighted divider type photo displays.
      • 9568
      I still have the Pentax P3 my Dad gave me decades ago... Kind of hard to find film and a processor nowadays anyway. Would be nice to put it to some use.
        LCHIEN commented
        "The Pentax P3 (marketed as the Pentax P30 outside North America) is a manual-focus 35mm film single-lens reflex (SLR) camera introduced by Asahi Pentax in 1985."
        35mm film and processing is still widely available though photo shops and mail in services. But not from your corner drug store anymore. if you drop it at a CVS or Walgreens, they will ship it to a processing service which will develop and print it and return it for pickup.
      Click image for larger version  Name:	20261020_095646.jpg Views:	9 Size:	238.8 KB ID:	863782
      Hmm, there are two kinds of LED bulbs. some have transparent envelopes all the way to the base (right) and some have opaque section halfway down the envelope (left).
      THe left one emits no light downwards when in a lamp. Probably works OK when base up in a ceiling fixture.
      So when I put that one in the lamp the bottom half of the shade did not get lit well. I said I had to use a 2.5" extension to raise the shade which exposed part of the socket base to view.
      Putting an all glass bulb in to emit light both up and down, I could reduce the extension to 1" and it is closer to my original design and hides the bulb socket and makes the proportions better.
        • 9568
        Yep. For lamps full glass LED bulbs are the way to go. The other type are rather directional...
