Two Hobbies Collide
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    Two Hobbies Collide
    (But only a little bit)
    I needed a reloading tray and had some scrap red oak. A little cut here, 50 holes drilled there, some router work, and voila.
  • RAFlorida
    • 1179
    Tom, that bullet tray looks like the way to go.
    Keeps 'em from rolling off the table onto the floor or your lap. Two great hobbies put together. Thanks for shooting us a post with jpgs.
    BTW, what's the caliber? Looks close to .50, but pictures can be deceaving.
    • Tom Slick
      • 2913
      • sears BT3 clone
      That's .40 S&W. I also reload .22-250.
        That's a handy tray. Same kind of one I use for drill bits, router bits, just about any tool with a shank.
          don't use collide and bullet in the same sentence.
          Nice Tray, do you make your holes nice and snug or kind loose fitting?
            They look kinda loose fitting.
            • Tom Slick
              • 2913
              • sears BT3 clone
              They're loose, all they have to do is hold the case upright.
              • tommyt654
                • Nov 2008
                • 2334
                Nice to know we have some other shooters here
                • Rand
                  • 492
                  • Vancouver, WA, USA.
                  I've got a custom made .22-250 that I inherited from my dad who inherited it from a friend of his. I've got a polaroid of the original owner holding the gun.
                  Rand
                    when i make stuff for woodworking i like it to be precise.
                    like when i made a peg game (like the ones at Cracker barrel) using wooden golf Tees I bought tees and calipered them by actual size into bins and used numbered drills to make them fit precisely - used a matched set of pegs for a specific board - it was a slick fit.
                    So I first envisioned your .40 bullets having a .405-.410" hole to fit precisely but I guess the rim at the end would require the hole to be somewhat oversize of the caliber.
                    Last edited by LCHIEN; 09-20-2010, 06:50 PM. Reason: replaced "flange" with correct term "rim"
                      • 9568
                      That is something I haven't tried yet. And I need some .270... Deer season is coming up shortly...
                      • lago
                        • 473
                        • Lago Vista, TX.
                        I made one similar to that to hold 100 rounds of .223 or .204 Ruger for spraying with case lube. Needless to say, the water-based lube raised the grain. Next one will probably be sealed with varnish.
                        Ken
                          I haven't shot in ages, the cost has gone up so much so since I was active. Tom, one thing that I just couldn't get right with my Lee setup was a tight crimp between case and bullet, do you have any trouble there? I would some times have exaggerated muzzle flash so I figured the crimp wasn't tight enough.
                          • Tom Slick
                            • 2913
                            • sears BT3 clone
                            No issues that I know about. I only crimp to remove the bell; nothing I reload has a cannelure.
                            • Bruce Cohen
                              • 2698
                              • Nanuet, NY, USA.
                              I gave up hand loading years ago, it started to interfere with my woodworking.
                              Considering the price of .45 (just about all I shoot), I may just get back into it.
                              Nice to see a fellow shooter.
                              Bruce
                              Samuel Colt did"
