Baby Crib Finished
    It looks like somebody's getting spoiled already. Very nice work. Congrats to both of you on the family addition.
      Very nice.
      • tjmac44
        • 76
        • Omaha, Nebraska
        Originally posted by master53yoda
        Speaking to one who will definitely know what I'm talking about. How did you cut the right angle notch the length of the closet rod that is in the top of the curve. I finally made a raised out-feed insert for my fence on the table saw and datoed mine in 2 passes. but it took a lot of thinking about how to do it to keep the dato straight lengthwise on a 1 1/2" rod.
        Your finish is nicer then mine. I have made the decision to never try something like that again with pine as it just does not finish as well as other wood and keeps any bumps that you do during construction.
        Art,
        The finish was a recommendation from many. I put on 4 coats with steel wool sanding in between coats. This finish really makes the figure in Maple "pop" right out. Surprise to me, there is a lot of small birdseye in the head board.
        I did the dado with my table saw and a jig. I left the blade 90 and made a 3/4 cut. Then rotated the rod 94 and made the second cute using the jig. This is also where I made a major mistake. During the first cut I had a feather board behind the blade.
        WARNING... NEVER USE FEATHER BOARDS BEHIND THE BLADE NO MATTER WHAT.
        The first cut was stable and went well. The second cut I forgot to take the feather board off. At the end of the cut, I watched the cut off piece take off like a missle thru the garage wall and into the living room. WOW. I was position way to the right of the blade and the wall was the only casualty. The feather board caused the cut off to get pinched by the blade.
        Back to the hospital I go, should be bringing baby home today
        Todd
        Grounded in fly-over country.
          • 9542
          Nice work on the crib...
          Nicer work on the youngun... Congrats!
          • master53yoda
            • Oct 2008
            • 456
            • Spokane Washington
            Originally posted by tjmac44
            Art,
            the reason I did mine with the dato is that i could not figure out how to contain the 1/4 circle piece that was 4 feet long from launching as yours did. I chose not to worry about the fact that the notch would be 90 degrees instead of 86 and glued it with epoxy to fill the difference in the angle. I'm glad that no one was hurt but i have to wonder how many people have used that crib plan and launched the same piece you did because of the tendency for the rod to Rotate.
            Maybe we should ask sarge how he would have done it.
            Art
            • tjmac44
              • 76
              • Omaha, Nebraska
              Art,
              My kick back issue was my own fault for using a featherboard behind the blade. So the cut-off piece, small wedge, was shoved back to the blade with the pressure of the feather board. The rod did not move at all. I used the same jig and technique, minus feather board, for the second rod with no incident. I will see if I can get a picture of the jig, if I still have it.
              How did you make your rods?
              Take care,
              Todd
              Todd
              • master53yoda
                • Oct 2008
                • 456
                the jig I used for the dado is shown in the 2 pictures the first is with both connected and ready for the dowel. (except for the dado blade) the second is the outfeed table that the notched portion rode on after the dado cut to 3/8ths
                On the second cut there was an infeed added that was 3/8 and the outfeed was changed to 3/4. I tried it at first with only the outfeed table but couldn't stop the rotation with out the containment jig that I mounted to the table itself and then the infeed table insert.
                Art
                  #23
                  I agree with those saying the kid learns to live with your habits, both good and bad. I have a recording room here, and the shop, and even in the womb the kid was being trained to be ok with the loud sounds. And in fact he is just fine with it. He sleeps well through drum sessions. We keep him far enough away that it's not LOUD, but it's not exactly quite either.
