Motor Frames
  • Kinreay
    Handtools only
    • Jan 2022
    • 3
    Motor Frames
    My BT300 motor frame has had the raise/lower thread stripped out. I had a helicoil installed but it was installed a little off center so now I can't run the blade up or down without using both hands and possibly wrecking it further.. Does anyone know if the motors from the BT3000 and 3100 are interchangeable? Apparently the motor frames are no longer availabe. I'd like to replace mine and if the BT3000 and Bt3100 frames are interchangeable, it will afford me more options. Also, does anyone know where I can get a replacdement motor or frame for my BT300? Thanks.
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    I have both saws, but the BT3100 hasn't been used since it first came out. I will have to look at the parts lists to see what things are interchangeable. May take me awhile, sorry.
    Jim Frye
    The Nut in the Cellar.
      Just so we know what we are talking about for sure, the BT3000 was offered with 2 different motors. A 13 amp, and a 15 amp. Do you know which version you have?
      • Kinreay
        Handtools only
        • Jan 2022
        • 3
        01-28-2022, 08:13 AM
        I finally was able to get to the saw and look at the motor. I had a look with a mirror to see if there was any info hiding out of sight, but no. There is no typical motor nameplate, just a paper tag with the numbers - 969214-008 120v.. No indication of the amperage.
          LCHIEN commented
          The Amperage of the motor is going to be on the nameplate of the saw itself. Assuming its got the original motor.
          Also the date code (four digit number YYWW) is a hint. 13A was only used for the first couple of years, 93-94 offhand.
      • Kinreay
        Handtools only
        • Jan 2022
        • 3
        Another trip to the shop and I see that there is a serial number tag on the saw and it says the motor is 15A. s/n 714599 9507.
          LCHIEN commented
          9507 is the date of manufacture code. 1995, 07th week (around Mid February) Happy 27th BD to your BT3000!
        For what it's worth, I HAD a 15 amp BT3000 I bought for parts for my BT3100, the motor housings appeared to be identical between the two. It was a super cheap Craigslist find and had a ton of accessories, so I bought it, and sold the rest for parts to the next guy for what I paid for it... The guy I sold it to managed to smash up the side / sheet metal on his and needed replacement panels and BT3000 rails so worked for him as well. Never seen him here though....
