Material for BT3100 ZCTP
  • tmaceroli
    • 132
    • Forked River, New Jersey, USA.
    Some great suggestions here! I did make one with a piece of 1/4" Poplar I got at HD. Didn't bother with the lip. It's OK in a pinch. I used a couple of washers at each corner to bring the level up. My next one will probably be out of a harder wood, I'l do some routing at the corners to avoid shimming, and I will definitely route out a relief groove for the blade. I've had to change belts once, and I'd definitely like to avoid a repeat incident.
    Tony
    "Nothing would be done at all if a man waited until he could do it so well that no one could find fault with it."
    - Cardinal Newman
    • tfischer
      • 2343
      I wish Lee (or someone) would sell these again. With my limited shop time I'd rather make stuff besides ZCTPs lol.
      The BT's throat plate design is probably my single biggest gripe about this saw. I get green with envy when I see how easy it is to make TP's for other saws.
        Internet Fact Checker
        • 20996
        The rectangular design of the BT3x seems much easier to build than the oval design for most other saws.
        I suppose you can use a router template following bit to cut the ovals if you have one to use as a template..
        For the BT3x the rectangular shape is easy to make but thin lip is a pain but you can just cut off or leave off the lip as others suggested.
