Inherited a BT3000
  • AJ77
    Handtools only
    • Feb 2014
    • 2
    Inherited a BT3000
    My father passed away about a year and a half ago. I finally started going through his shop and decided to bring his BT3000 home to replace my craftsman direct-drive. I was getting ready to rip some stock, and saw my father had a crosscut blade on the saw, so I tried to replace it, and that's where the problem came in. I can't get the arbor nut off. It spins, then binds back up. So I think I'm going to need to replace the arbor rod and nut at least. How tough an operation is this going to be?
    • 9550
    Are you using both spanners to loosen the arbor nut? And what direction are you turning? These might seem like obvious questions, but you never know. A lot of newbies don't know how to properly remove the blade...
      • 22051
      its a left handed nut (Keeps it from coming loose under operation forces) so it loosens in the opposite most all others nuts you're used to.
      You should be using the two spanner wrenches, each one has a slot which locks the arbor behind the blade and the other (a 3/4" open end wrench will do) to remove the arbor nut.
      Not sure what you mean by spins then binds back up - are you unable to lock the arbor in place? That's what one of the spanners will do for you.
      • AJ77
        Handtools only
        • Feb 2014
        • 2
        Thanks guys. Went back and tried again. I had gotten so frustrated with my day yesterday that I forgot about the reverse threading on arbor nuts. Everything is working fine, just had to take a breather and check in with knowledgeable folks to get my head back straight.
          • 9550
          It's good to know you got it going...
