saw table "cupping"
  • weilin
    • Jul 2011
    • 15
    • Encino, CA
    saw table "cupping"
    Hi everyone,
    Newbie here. so I bought my bt3000 about a year back from craigslist. a carpenter friend of mine suggested it as my first saw to break my woodworking cherry, and it has surved me well. Over the past year, i have learned to calibrate a number of machinery. So I thought it was time for me to tune up the ole' bt3k. I was trying to level the saw when I put a 4' level across the saw table and noticed a bit of daylight under the level. I thought maybe my level was warped. So I put my newly purchased Starrett 36" straight from edge to edge across the saw table, and used my feeler guage to see if there indeed was a gap. Wouldn't you know it, towardes the middle of the saw table, I was able to slide a .005 inch feeler guage through. Now, I know 1/200 of an inch may not sound like a lot. But i was just wondering if anyone else noticed the same thing? And if so, is there a fix or is this just one of those Ryobi tolerances that I need to come to terms with. Does aluminum wear over time? Will this get worse? Thanks in advance for any input.
    -W
    • 22051
    Welcome to the forum.
    first of all, the BT3000 tables are aluminum, probably cast, then anodized and machined flat - you can see the raw aluminum and machining marks on top of the ridges.
    I don't think its too easy to wear .005 aluminum off of a table even if its 50% ridged, considering that altho aluminum is soft compared to iron, its still much harder than wood. Especially if its already a low spot - if anything you'll wear off high spots and the edges.
    Finally, I don't think .005" is much to worry about in woodworking.
    My advice is to relax and enjoy the woodworking.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      Quit measuring it...you'll get much better results!
      Seriously, let the cuts tell you how the saw's performing.
        • 9550
        If we were talking cam shaft bearings on a high performance engine that spins at 7K RPM for hours on end, they that 5 thousandths would make a difference, but for the surface of a table saw? not so much... I would worry more about that sort of variation on a jointer, or a hand plane, but not the table saw...
        • scmhogg
          • 1839
          • Simi Valley, CA, USA.
          Welcome to the forum...neighbor.
          Steve
          • weilin
            • Jul 2011
            • 15
            • Encino, CA
            Thanks for all your perspectives and good points. I suspected that I should just let this go. But being new in woodworking, its hard to know what to let go and what not to. I learn as I go along.
            Steve, good to know there's a neighbor in the valley on this forum.
            -W
              • 8793
              Welcome! I will add a note that is not directly related to your problem but does relate to alignment with the whole top and rails:
              There have been times when rails didn't seem to be in plane with each other. This happens during setup and tightening of the legs as much as anything else and it also happens when the table is set on an uneven floor.
              • Lonnie in Orlando
                • 649
                • Orlando, FL, USA.
                Kinda adding to what Hank said ...
                I saw Kelly Mehler at a woodworking show a few years ago. He was showing how to set up a table saw. He said that a table saw top can warp if the legs are not adjusted correctly when sitting on an uneven floor. A straight edge laid across the table in one direction will rotate on the high spot. It will not move when laid 90deg to the first position.
                Perhaps the little table on a BT3K could warp over time - I dunno.
                - Lonnie
                • Bruce Cohen
                  • 2698
                  • Nanuet, NY, USA.
                  As you mentioned that you have just started in woodworking, I doubt that a .005 difference will affect your work. It takes a long time to be able to cut joints that really require that degree of accuracy.
                  It's wood and wood moves, so .005 in no big deal.
                  Bruce
                  Samuel Colt did"
