Yikes!
  • durango dude
    • Mar 2011
    • 937
    Yikes!
    Well - was using my BT to cut some oak - and the throat plate popped up and tapped the blade -----
    The blade's fine ---- but I had to switch the throat plate to my zero clearance.
    Only down-side --- no more kerf/anti-kickback.
    Was a little surprised and scared when the saw grabbed the throat plate, though ---- will be bolting it down for now on (once I get a replacement).
    • 22085
    scares me to think of a loose throat plate next to a madly spinning blade. I know some saws do that but I wouldn't like it.
      No way I would turn my BT on without the throat plate screws in place.
      • durango dude
        • Mar 2011
        • 937
        lesson learned ---
        By the way - nobody can convince me the BT3000 is under-powered.....
        I've got a sawed off throat plate to prove it....
          I cut an opening for my riving knife in all my ZCTPs, as well as use all 4 screws.
          • jking
            • 972
            • Des Moines, IA.
            Same here. The owner's manual instructs to cut the ZCTP for the riving knife.
              I first used the OEM plates, but they will flex a bit, especially after the slot is cut for the knife. The ones I made from some maple flooring a much more rigid.
                • 9561
                I can't imagine trying to use the saw without the throat plate securely fastened. I don't even like the OEM plate that only screws down to the front... That scares me too...
                  ???? I don;t get it. Why does your OEM plate screw down only to the front? I have four screws for regular as wells as ZCTPs.
                    BT3100 has spring clips in the back and a single screw in the front IIRC.
                      • 9561
                      Exactly. Not sure why but the spring clips on mine have a habit of coming loose.
                      My ZCTPs have 4 screw holes, my dado insert has 3. I hate my OEM standard plate though... For what it's worth, I only use it for bevel cuts...
                        "Nevermind."
                        - Emily Latella
                          The OEM steel plate on the Craftsman 21829 has 3, one in the front and two in the back. The Craftsman plastic ZCTP have 4 screws.
                          • jking
                            • 972
                            • Des Moines, IA.
                            Mine is difficult to pop in & out. Do your rear screws need to be tightened?
