Dado Blade set
On my BT3100, the teeth of a 6" dado clear the trunning by what looks like a 1/64". Since the trunnion is slightly tapered, an 8" dado would definitely be hitting it. I would not get an 8" for a BT3100. The SD206 makes excellent dadoes - clean, with dead flat bottom.Comment
I've been following this thread with interest preparing for the timing and finances that will allow for a dado blade set purchase. If I'm not mistaken it was either here (this board) or in the owner's manual (I need to review it) that I remember reading the suggestion of 8" blades, but I've learned that may be larger than necessary for most dado cut depths (thanks for pointing this out to me Loring).
I just got more confused reading an 8" blade set will hit the trunion. I guess I need to understand this (trunion???) better so I can be aware & check clearances. If it would hit how are others running an 8" blade set?Comment
Read my other reply - the 8" will go on if you leave one 1/4" spacer.I've been following this thread with interest preparing for the timing and finances that will allow for a dado blade set purchase. If I'm not mistaken it was either here (this board) or in the owner's manual (I need to review it) that I remember reading the suggestion of 8" blades, but I've learned that may be larger than necessary for most dado cut depths (thanks for pointing this out to me Loring).
But that causes problems at the other end on wide dados.
For a more in-depth answer: trunnions are the metal parts that support the arbor and move when you change blade height/angle. The BT3100 trunnion has a slight taper towards the blade. On the arbor, there are two spacers, a 1/2", and a 1/4". When using a regular 10" blade, you put both spacers on the arbor in order to cover the large non-threaded portion of it. When using dadoes, depending on how wide is the cut, you'll need to remove either 1/4" or 1/2" or both spacers. For 3/4" dadoes, both spacers gotta go off, or parts of the dado stack will end up on the arbor threads - which is bad, since threaded part is slightly thinner. (not the wisest arbor design, IMO. My RAS arbor is threaded all the way, but the thread is flat top, and is same exact diameter as all of the arbor)
Well, in my BT3100, with both spacers off, teeth of a 6" dado barely clear the trunnion. An 8" would hit it. However, due to manufacturing deviations, I understand that on some saws, an 8" dado will clear.
Now, if you already got an 8" set, it is not so bad. Taking a file to the trunnion for about half a minute in the rght spot should take care of the problem.Comment
I just want to point out another set that I just saw in the latest Rockler catalog. They are now carrying an Oshlun dado set (6" or 8") that looks just like the Avenger set that I and many others have. A quick search on here will get more information on it. If it is the same set (which a google search indicates that it probably is) it cuts well, but takes a bit more setup than the Freud. The 6" is about $60. I have been happy with my set, and if this really is the same, would reccommend it as a good budget option to others.
edit:
I just checked the website, and rockler doesn't have these items online. The January 2007 catalog has them on page 4. The item # is 21947.Last edited by jziegler; 01-24-2007, 05:35 PM.Comment
Footer Ad
LCHIEN
