Deal alert: Freud 8" boxcutter blade set $25 at Sears
  • jtrcy
    • Jan 2005
    • 182
    This was posted a while back on Woodnet, and some members are helping themselves to multiple sets, but I just found a set at the Livonia MI Sears, so they are still out there if you look.
    They are marked $99.99, but mine rang up for $24.97. Comes in a very nice holder as well.
    Good luck!
    Julian
    That Freud box joint set is really nice. Crisp, clean, flat 1/4" or 3/8" joints every time.
    That's a steal at $25!
    • herb fellows
      • New York City
      What he said! I paid about $ 55 and I thought I stole it.
      $25 is an extremely good deal.
      Nice find1
        I think I'll be out that way tomorrow. Might check it out.
          • 3760
          I have found the close out tools at Sears in a Clearance section hidden in a corner. Their close out items may not be the same place in every store, but it does look like they pull the items off the shelves and let them pile up before someone gets around to marking it down.
          capncarl
          • Greg in Maryland
            • 250
            I picked up the last one at my local Sears. Thanks for the tip.
            Greg
            • Les
              • 48
              • Portland, OR area
              Darn!
              No such luck out here in WA state. Called the local store and was told that this set is only available online. On the Sears website the SBOX8 set is a whopping $70 and it's not even sold by Sears, but an affiliate store.
              I guess I will just have to make do with my dado set... I understand that the box cutter set comes with some nice instructions on how to make a box joint jig. Any of you lucky shoppers care to scan and post them? TIA
              • KC7CN
                • Aug 2007
                • 73
                • Deltona, Florida
                • PowerMatic 64A
                Sears has been closing out the Freud line of saw blades & router bits during the last 2+ years. I first noticed the router bits in the Clearance rack a couple of years ago when we lived in central Washington state; picked up quite a few bits - dirt cheap! A little later on there was a big reduction in price on saw blades - about half off. We live in Oregon now, and I found a 24T full-kerf rip blade for $18; last original price $37.99. When I was in the store today I couldn't find any Freud blades!
                -Don
                • phrog
                  • Jul 2005
                  • 1796
                  • Chattanooga, TN, USA.
                  I've never owned anything like this and I am trying to figure out - what is the difference between the boxcutter blade set and a dado blade set?
                  Richard
                    • 22029
                    the Freud Boxcutter is a very specialized dado.
                    Cuts only 2 precise sizes 1/4" and 3/8" with very clean edges and flat bottoms, Specially made for 1/4" and 3/8" box joints.
                    P.S. As Erik said below there's 2 different blades, call them A & B. They can only rotate one way of course.
                    So if you put A on the right and B on the left then the you get the 1/4" "kerf" and if you put B on the left and A on the right then you get a 3/8" Kerf.
                    I haven't handled a set myself but the way this is done I expect is that the cutting teeth are offset to have 1/16th more on one side than the other. The "A" blade would have the extra offset on the right and the B on the left.
                    When in the 1/4" configuration the A on the left then the extra offset will be "hidden" by the B blade by meshing the teeth in one to the gullet in the other. Swapping the blades puts the extra 1/16th offset on the outsides and cuts 2 x 1/16th (=1/8") wider kerf.
                    Some dadoes (like my Freud SD306 and 308) use ATB teeth on the outside side of the blades to make clean crosscuts but this leaves a very slight groove on the outside edge of the grooves.
                    On this one The teeth are flat-top grind to give perfectly flat and square-corner kerf bottoms. The diameters and tooth widths carefully matched with tight tolerances to make smooth across-the-bottom cuts and perfect widths. Which is partially why the set of two blades is $100 list price.
                    I'd sure like to have a set for under $50 but there don't seem to be any around here.
                      The Freud set has two blades with wide offset teeth. Facing them together in one direction produces 1/4" cuts and face them on the other sides will do 3/8" cuts. They produce absolutely flat bottomed cuts like a higher end dado stack should.
                      • smckinney
                        • Jul 2010
                        • 7
                        The Sears store in Everett, WA had four or five of these left yesterday afternoon. I hope this helps.
                        Scott
                        • phrog
                          • Jul 2005
                          • 1796
                          Thanks Loring and Erik for answering my question about the difference between a dado set and this set.
                          Richard
                            I bought a set off FleaBay a year or so ago. Only used it a couple of times, but it is great.
                            I have an odd sized picture frame that my oldest made for my youngest as a wedding gift. I remaking it to hold a 16x20 and am going to use the box joint blades to recut the splines. A single blade may be wide enough. If not I will go with the 1/4 set up. Should get a nice kerf with it/them.
                            • Les
                              • 48
                              • Portland, OR area
                              What about using a router?
                              I'm in southern WA and haven't had any luck finding these blades. So I have been trying to console myself with the thought that I can just use my router for making box joints. For those who have done it both ways, is there much of a difference?
                              P.S. Found a Craftsman set of molding triple cutter heads for $30 (model #93217) -- is that a good deal? Could they be used with the BT3000?
