$203 Delta JT360 6" Jointer/stand (46" bed) clearance at Lowes
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    This bargain was reported in this recent post by phrog - Sorry for the repost, but I wanted to title to reflect the new lower price because it really is a steal at this new price. phrog, berickso et al get the credit for finding this deal, of course -- I just took advantage of it.
    Lowes item #60009. There's a receipt posted on the other thread. I'll post another receipt if anyone needs it. The yellow tag shows it as on clearance for $313, marked down from $369 -- but it rings up at $202.95 -- that's about $1 per pound. Same jointer on Amazon.com is over $415 so it really is steal at $203.
    46" bed, open stand, 3/4 hp motor, ~5" fence +-45 degrees, quite heavy (>200 lbs), ~2 hours to assemble, works GREAT!
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    might as well post the receipt if possible, it might prove to be helpfull to those who want to get one.
    omar
    • just started
      • Mar 2008
      • 642
      • suburban Philly
      Looks like you have to go into each store to see if they have any, I have looked on line at about 40 different stores, including those mentioned in these threads, and I get 'can't find' everywhere.
      • kevincan
        • 181
        • Central Illinois
        I was at the Lowes in Champaign IL today and they had one on the floor for $202 and change. If I did not have a jointer already I would have bought it.
        Kevin
        • berickso
          Handtools only
          • Aug 2007
          • 4
          Ignore what the website says about availability. Once an item goes non-stock, the website will immediately start saying it's not available.
          Call your local Lowes, give them the item number 60009, and if they say they have none, ask if any other stores in the district have them in stock.
          Good luck!
          Brian
          • phrog
            • Jul 2005
            • 1796
            • Chattanooga, TN, USA.
            Hey Alex,
            Don't apologize for the repost; I'm glad that you did repost since the price you're quoting is more reflective of what most people are finding. Unfortunately, at the nearest Lowes to me, it is still showing over $300. Hopefully it will ring up at $202 like it did for you if anyone is interested. It's a steal at the price you found and I hope you enjoy using it - looks like a really good machine.
            Richard
            Richard
            • Micham59
              • 7
              • N.E. Ohio
              jt360 bargain alert
              I want to thank phrog for the heads up on the delta jt360 at lowes. I have been looking for a deal on a jointer for a month or so. I found a used one ebay for a starting bid of 175.00. I put a max bid for 210.00 then I saw phrog's alert. Well the auction ended around midnight est. last night. I got outbid because I am not staying up until 12:00 to bid. This morning I went to lowes in Niles Ohio and the one on the floor was priced at 369.95, so I took the number to the register to see what it rang up at. The girl said 202.95. I asked her how many they had and she said three. Well if you go there now they only have two. I am very happy I got outbid now I have a new one instead of a used one. Thanks again phrog
              • Navycraig
                • Aug 2006
                • 30
                I'm on high alert and have to call the store back in a half hour to see if they actually have it. This would be SWEET.
                Question though. Can a "joiner" of this typed also be used for planing of stock up to the size the tool is rated for?
                • Alex Franke
                  • Feb 2007
                  • 2641
                  • Chapel Hill, NC
                  Yes -- it's perfect for planing up to 6" wide stock -- then adding a perfect 90-degree edge to it.
                  You'd use it to flatten one face and create one 90 degree edge. Then you'd use a thickness planer to make the other face perfectly parallel, and then a table saw to get the other edge. (Some people use a table saw to trim the other edge 1/8 wide, then finish it up to the correct width on the jointer.
                  BTW, don't forget to pick up some Johnson's paste wax for the surface (or some other surface treatment) if you don't already have some.
                    Adding to what Alex wrote ... while this tool is known to some as a "jointer/planer," the two jobs it really does are edge jointing and face jointing -- i.e., two variations of the same thing, but involving different parts of the board. When talking about the wider faces of a board, "planing" is not incorrect, but "face jointing" invokes the better mental image.
                    A jointer flattens the surfaces of a board, but cannot make the opposing surfaces parallel. A thickness planer makes the opposing surfaces of a board parallel, but the board will not necessarily be flat. This is why you really need both tools.
                    • MBG
                      • Apr 2003
                      • 945
                      • Chicago, Illinois.
                      I have a 6" jointer and have face joined boards as wide as 9". You pass the board through both ways with a slight overlap. Not something you do every day but useful when needed.
                      From my short, maybe 3 year, experience with a jointer and working with rough sawn lumber I find you get the most out of the lumber by breaking it down into thinner strips. For example, if you have a 1/4" cup in a 12" wide board, if you cut it in half you half the amount of warpage.
                      Good luck finding one!
                      • Navycraig
                        • Aug 2006
                        • 30
                        Well, after much debate with a store employee, I got it for the $202.95. I have to drive an hour (and take my wife to dinner and ice cream) to get it, but I'm stoked.
                        They told me $313.00 at first and stated that they did not have to match another Lowe's sale price...that it was up to each individual store. After telling them about my 15 minute hold, being hung up on and a few other things...they agreed.
                          You can also do this on a TP i.e plane boards on end. You need to make sure they are not to tall, generally I use a 1 to 4 or 5 ratio. You can also gang boards together with a clamp (make sure it will clear the sides of the planer). I did this only yesterday with 6 3/4 pine boards (3' long).
                          I jointed the edges of 2 boards. Sandwiched the other 4 between them a fraction higher and making sure the 2 jointed end boards were level. I then ran it through the planer and effectively jointed the other edge of all 6 boards at the same time. I then flipped it over and ran it through again to get to final width.
                          • smokeaterc
                            • Dec 2007
                            • 6
                            • Stone Ridge, NY
                            • Sears 21829
                            Picked up mine today !
                            Thanks for posting the clearance price. I stopped at the Lowes in Highland, NY on the way home from work today and they had the clearance price posted on the floor model $202.95. They had one available (not including the floor model) which they loaded into my SUV. Can't wait to give it a try.
                            • DLyon
                              • 78
                              Picked mine up today, $196.09 out the door. (Denver, CO)
                              The Greenwood Village store is supposed to have 1 more and the Grand Junction store shows 2 in stock.
                              I used a 10% off coupon in conjunction with the sale price. It's unloaded into the garage, but that's as far as I got this evening.
