well something went right.
    • 22081
    I know the AC worked fine yesterday. Today both of us went out and came back after noon. By 1:30 it seemed to be getting warm so I checked the AC and it was set at 76 but the inside temperature was 82 and outside it was 94 high today. The air blowing out of the registers was over 80.
    I called the AC service company I used last time at 2:00 and they had a guy at the house at 2:30.
    He checked the system and said there was a loose 230V wire on the contactor arcing. They had replaced the start capacitor on last visit.
    He said it was still under warranty and there would be no charge.
    Gone by 3:00
    That is the fastest and cheapest AC service I have ever had in 51 years of owning homes in Houston.
    • 8801
    It sure is great when those rare things/times happen!
      • 9560
      Shocking! Good to know you got it fixed up quick especially in this heat...
        • 22081
        When I called the A/C service company it was Friday afternoon. Their first offer was, "Is Monday OK" to which I responded, "No,"
        She called back a few minutes later and said a guy was on his way, he was at my house less than 30 minutes later. Lucky me.
          capncarl commented
          While I have a really good mini split ac system in my shop where I could temporarily retreat to if the house ac bit th dust, I have a 120v window ac back up that will keep the master bedroom comfortably cool. Nothing like sleeping in your bed!
        • 22081
        I had 17 new windows installed yesterday. For most of the day I had several 4x6 foot holes in my walls open to the outside when it was in the upper nineties. The air conditioning worked about as well as it did when it was not working at all.
        • Jim Frye
          Jim Frye commented
          You didn’t turn the AC off during the install? We had 19 Pella replacement windows installed in our previous home and the installer foreman asked us to turn the system off to reduce dust being blown around while they were cutting out the old wood windows. They held a shopvac hose under the demo saw to catch the cuttings. They also covered HVAC vents in any room they worked in. Don’t recall the ambient air temperature, but it was pretty in the summer time.
          LCHIEN commented
          well they didn't suggest it. They put up plastic sheeting barriers around the windows they were working on and that helped some. Overall keeping the air on kept the house from being toast. They did use shopvacs to collect cuttings from the saws.
        • 3790
        Loose 220v wire loose in the contactor? That term seems to be popping up too often! I’ve had a clothes dryer power receptacle melt down in the wall outlet recently. It appeared that was what its problem was! Then a ground fault interrupter started tripping for no apparent reason, after it replaced it in the house panel I tightened all the wiring connectors in the panel and found 1 circuit that had its wire that was apparently never tighten down.
          capncarl commented
          Last summer our 2 yr old ac died on a Friday afternoon 15 min before the AC co closed. They sent a tec right out who diagnosed a cooked motherboard due to a rainfrog. After they replaced the board and left I opened the ac up to frog proof the control panel…. That’s another rant for another time…. Before I closed up the panel I checked all the wires and connections and found a loose wire that was unrelated to this problem. Doesn’t any installer tighten anything?
          leehljp commented
          I too, replaced a circuit board in the outside unit due to a rain frog on a church AC system. The pastor and deacon said they would trust me to replace the board for free if they ordered the board. They did - against my will, then I grudgingly replaced it and it worked fine. I took a dozen or so picts up close and from about 18 inches so that I could replace the right wire onto the correct place. It worked. I did get some free work from them for that bit of work. After that replacement, we frog proofed the unit also.
        • 22081
        Rain Frog???
        In the electronics? Is this common? I don't even know what a rain frog is.
        Ai says they are native to parts of Eastern and Southern Africa.
          leehljp commented
          I'm thinking that different parts of the country use different word for similar frogs, etc. I call them "tree frogs" although there were no trees within 200 - 300 years of the church AC that I worked on.
        • 3790
        I’m not an authority on frogs but thems some ugly frogs! Our rain frogs are cute little green frogs that like to reside in air conditioner units and Bar B Que grills. In the rare cases that we get rain they congregate in the rain gutter and sing!
          • 22081
          Tree frogs I know, those cute green ones.
            • 3790
            Ours is the regular tree frog, no orange hands, fingers and eyes, just pale green. Except for dead petrified ones stuck to the AC fan guard I seldom see them except when I roll the Big Green Egg out on the patio and pull off its cover, then the little buggers scatter like rats from a sinking ship. I guess they have learned that the cool ceramic egg is about to get really hot!
            Another Old Man Rant! Air conditioner manufacturers continue building equipment that draws critters like frogs and is highly susceptible to damages when they get into the electrical components, and they make no attempt to guard against them. After our new Rheem AC was disabled by a frog, and then repaired by the installing dealer I took the unit half way apart to “critter proof” it. OFF COURSE THE POWER WAS OFF. There were numerous places that I could stick my fingers into the electrical compartment, a herd of frogs could get in. I installed screens over the large cracks and caulked or metal taped over the small openings that the manufacturer might claim were for cooling purposes.
            The repair technician told me that damages such as this is common, and they often recieved calls to find snakes of all sizes in the electrical panel and even wound around the fan blades.
            We have since removed all shrubbery from near the AC and replaced the pine straw and mulch with river rock. I won’t put up with a dripping wet snake attracting machine at my back door!
